SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING?
#1698904
11/14/14 01:05 PM
11/14/14 01:05 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Are there any small block aluminum heads on the market that appear relatively stock, for example, from the outside, having the front/rear, with the core plugs? Without those plugs, its a dead giveaway that the heads are aluminum. I'm aware that the BB heads have some stock appearing aluminum heads (from the 440-Source company?). T/Anks ahead! ![](/ubbthreads/images/graemlins/wave.gif)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: SMALL BLOCK ALUMINUM HEADS - STOCK APPEARING?
[Re: B1MAXX]
#1698909
11/14/14 03:20 PM
11/14/14 03:20 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Just get some iron W2's if you want performance and the stock appearing look.
[Re: Guitar Jones]
#1698913
11/14/14 09:45 PM
11/14/14 09:45 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
+1 Especially if you get an older casting that doesn't say W2 on it
[Re: SpareParts]
#1698914
11/15/14 02:14 PM
11/15/14 02:14 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The answer to your question is "There isn't one" There are a couple candidates that get close, neither has been manufactured for many years, and both are fairly rare to find. Batten Heads: While not an exact match to factory 915 castings, these looked the most like stock castings, water jacket plugs in the ends, rough cast ends, etc. they would fool most anyone if painted orange. These were made back in the 1980's or there about, no longer made. They had some pretty well known casting issues, porosity, leaks, etc. Some were good, some were junk, total crap shoot. Most I've seen were already ported by someone, again, total crap shoot, it either improved them or turned them into junk. Diamond W2 heads: These have rough cast ends which resemble cast iron when painted but lack the core plug on the ends that stock heads have, again, you'll fool a lot of people with these but sharper eyed Mopar guys will spot the lack of the plugs. These were made my Diamond Racing products back in the 1980's (Diamond is still in business making pistons but not heads). These were in the Direct Connection catalog for sale to racers back then, VERY expensive for the day, and good castings, the flowed BIG numbers if given even a mild port job. There were some reports of some porosity issues but I've had a few sets of these and all of them so far have been beautiful. Same story as Battens, hard to find, often ruined by previous porting efforts, etc. The typical racer mentality seems to be "Who cares what it looks like if it works" but I feel there is a good potential market for a stock looking aluminum head, there are a good number of guys that I know whom would like to keep their car looking stock but would like to improve the performance. ![](/ubbthreads/images/graemlins/Twocents.gif) *Batten heads shown on this engine
[Re: ScottSmith_Harms]
#1698917
11/15/14 05:10 PM
11/15/14 05:10 PM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
Cast Iron W2 for comparison
Note: not an 'end shot' but best one I have, looks pretty OEM in the most aluminum heads are slab sided like a bar of soap and easy to spot.
[Re: pittsburghracer]
#1698921
11/17/14 04:25 AM
11/17/14 04:25 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
With some splash-zone epoxy and paint anything can look stock.
Until you hit a certian ET and they start looking under the valve covers for casting numbers and looking of ALum part that should be iron.
#1698923
11/17/14 05:25 PM
11/17/14 05:25 PM
Mopar Mitch
Thanks to all for their feedback, tips, suggestions, and 2-cents. etc.
Mopar Mitch
