small block 727 #1698843
11/14/14 02:18 AM
11/14/14 02:18 AM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
I have a 360 w/trans that a fellow is interested in buying. I was told the combo was previously used in a b series van. This fellow wants to use it in a '66 Baracuda. Our concern is; will the trans fit? I know the 360 will fit in place of the current 318 he says is in the car. He thought the tailshaft might be too long for the car. Are there different length tail shafts for a van/truck versus car applications? Thanks for all the help.
Re: small block 727 [Re: poison_ivy] #1698844
11/14/14 03:02 AM
11/14/14 03:02 AM
if it is a std 727 with the long car tailshaft it will fit. The dimentions are (I believe) in the archives here
Re: small block 727 [Re: RapidRobert] #1698845
11/14/14 11:58 AM
11/14/14 11:58 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You need to look at the tail shaft, too. If the 66 Barracuda is a floor shift, then the tail shaft of the 727 needs to have two mounting holes on the bottom side up close to the cross member mount. That is where the bracket goes to secure the bottom bracket for the floor shifter.
Re: small block 727 [Re: fastmark] #1698846
11/14/14 12:12 PM
11/14/14 12:12 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The only differences in 727 tail shaft lengths that I have found have involved 4 wheel drive transmissions. If the van was a 2wd I'd check for the two holes previously mentioned for the floor shifter mount ( can't remember if those were utilized in 66?) and go.
...FAFO...
Re: small block 727 [Re: skicker] #1698847
11/14/14 04:27 PM
11/14/14 04:27 PM
Visalia, CA.
P
P
Visalia, CA.
Doesn't have the two mounting holes. The guy already has a tranny in the car. Push come to shove, the guy can work out the tailshaft issues afterwards. Thanks guys for the info. BTW, here's my latest project. /6 w 3 on tree. Gonna swap to auto tranny. Thinking of an Offenhauser 2-1bbl manifold and bumping the cam a little. Truck is really clean and a blast to drive. Gets a lot of thumbs up and others scratching their heads.
Re: small block 727 [Re: poison_ivy] #1698848
11/14/14 06:35 PM
11/14/14 06:35 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
the torque shaft for his 904 will not fit the 727 properly.A 727 is wider and the torque shaft used on 727's in an A body is about 1" shorter than the 904
..the frame and trans brackets are slightly different as well.
Re: small block 727 [Re: can.al] #1698849
11/15/14 05:40 AM
11/15/14 05:40 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
IIRC the driveshaft slip yoke is different between the 904 and 727, but it has been since 1979 when I last cared about a 904
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
