Hurst Super Shifter 3...??? #1698255
11/13/14 09:02 AM
11/13/14 09:02 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Bought one (and the kit) years and years ago and just recently sold the transmission i was going to put it on. Now i'm on the fence about selling it or keeping it for the next project. A guy came here and was telling me it was the greatest thing since the wheel... an awesome shifter. When i bought it i wanted the BEST shifter i could buy that accepted a pistol grip and required no cutting.
Any experience with this shifter?
Now that i'm thinking about selling it i checked out the usual suspects (Jegs, Summit), and found out its long disco'd. Checked E-bay and i see them for utterly ridiculous prices... WAY more than i paid ten or so years ago. I got mine for a wicked deal at the time, so i have no idea what they cost new.
How much were they new? Anyone remember?
Re: Hurst Super Shifter 3...??? [Re: Pale_Roader] #1698256
11/13/14 12:21 PM
11/13/14 12:21 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
I currently have one in my car along with my son. They are the same as a Comp. Plus shifter, except for the reverse lock out. Also, the lower arms are a tad longer allowing for a short shift pattern. It is a very good shifter and is no longer produced. Remans are available from time to time. Original cost, if I recall were around $250.00 +/-.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Hurst Super Shifter 3...??? [Re: Pale_Roader] #1698257
11/13/14 01:20 PM
11/13/14 01:20 PM
Massachusetts
Roadster Offline
Roadster  Offline
Massachusetts
Just my two cent's : I ran an AAR Cuda with a super shifter mine may have been a little different as it was mounted on an inverted L shaped bracket which allowed for straight shift rod's and as far as I am concerned it was the best shifter available. If I were going back to a stick in my stocker which I may I would use one again Bob
Re: Hurst Super Shifter 3...??? [Re: Roadster] #1698258
11/13/14 02:41 PM
11/13/14 02:41 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Correct! Best 4 spd shifter ever made IMO.Problem is you have to modify the floor and the hump to use it as the shifter is located in the car and not under the floor.Tight fit with bench seat. Last I checked with Hurst it is still available but must be bought in pieces(rods,L bracket etc) ,not as a complete unit like the old days.Factory 71 up set up mimics the set up but is not as heavy duty.Big improvement over the comp plus and not the same unit.
Leave the gun.......take the Cannoli's....Mike
Re: Hurst Super Shifter 3...??? [Re: mike s] #1698259
11/13/14 04:20 PM
11/13/14 04:20 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Unless I'm missing something here, you guys are talking about a different shifter than the Super Shifter 3. I believe you're talking about the Ram Rod shifter. It had the same body as a Comp. Plus and Super Shifter, but was an "INLINE" shifter. In either case, floor mods weren't necessary if going into a stock stick floor pan.
All three used the same mounting pad. It is preferred to have all shifter rods as straight as possible. I'm using custom made(by me) straight rods with my Super Shifter 3 right now.
Re: Hurst Super Shifter 3...??? [Re: 68LAR] #1698260
11/13/14 04:27 PM
11/13/14 04:27 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Not an inline shifter or a rachet shifter. H pattern with L bracket and longer,larger rods.Used by most of the early pro stock drivers when they used the Hemi 4 spd incl Sox,Landy etc etc.Ram rod came later.They called them Super Shifter 1,2,3, came later.
Re: Hurst Super Shifter 3...??? [Re: mike s] #1698261
11/13/14 04:31 PM
11/13/14 04:31 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Ya got me there. I've seen the "L" shaped brackets used with "E" body cars and Comp Plus body shifters with and without the reverse lock out.
Re: Hurst Super Shifter 3...??? [Re: 68LAR] #1698262
11/13/14 05:13 PM
11/13/14 05:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
This is a Super Shifter III mounted with the Supershifter install kit. It did require butchering the floor. If you don't want to cut the floor then mount it on the standard Competition Plus bracket. They never made a kit like this for the E body because the shifter is already high and rearward. When I bought a SuperShifter for a Cuda back in the early 70's I called Hurst and asked why there was no listing for an E body kit and they said just buy the tower and a 7" straight handle, no need for a kit. The kit was for A and B body cars that had the forward mounting point.
Re: Hurst Super Shifter 3...??? [Re: GomangoCuda] #1698263
11/13/14 05:25 PM
11/13/14 05:25 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Thanks. My day is complete. I learned something new.
Re: Hurst Super Shifter 3...??? [Re: GomangoCuda] #1698264
11/13/14 08:48 PM
11/13/14 08:48 PM
Swears too much
Swears too much
Oh joy. More confusion.
Sooooo... the shifter i have, which is exactly as pictured here, WILL fit my 70 Challenger without cutting? or wont?
And also, is there any reason why these things are retarded prices on Ebay? Theres one, shifter only for $400. There's also a complete unit for $900, and another complete unit (though signed by someone famous, i forget) for $1300.
I think i paid $3-400 for mine.
Re: Hurst Super Shifter 3...??? [Re: Pale_Roader] #1698265
11/13/14 09:30 PM
11/13/14 09:30 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have a Super Shifter in my AAR right now. It is not the III like pictured, but the lockout is just pushing down for reverse. It came with the kit that included long, straight rods and a big "S" bracket that moved it up and over. It would have required me to cut the the hump more to use it. I did not want to do that. I just used the OEM rods and levers and it works great. Best shifter I've ever had. I has a shorter throw and is very positive. Every time I drive my buddy's 4 speed Superbird, I want to break into a round of " Row, row, row your boat, gently down the stream"!
Re: Hurst Super Shifter 3...??? [Re: fastmark] #1698266
11/16/14 08:17 PM
11/16/14 08:17 PM
GomangoCuda Offline
GomangoCuda  Offline
I have the same SuperShifter II as Fastmark in my Barracuda. Uses stock ebody rods, levers, mount and boot. No cutting what so ever.
Since you won't need the bracket and rods anyway you can buy one out of any car. Mine started life in a vette and cost me $125 on ebay. The vette bracket and rods are somewhere in my garage. Anybody want them?
Re: Hurst Super Shifter 3...??? [Re: Pale_Roader] #1698267
11/16/14 11:30 PM
11/16/14 11:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Here's a picture of the E-body Supershifter III that I use in my Savoy.
It does not use the reverse lockout that most Supershifter units have and this is my second Supershifter that I have owned without the lockout. I really don't know when where or why they made them both ways but in either form they are a very nice H-pattern shifter
At a weekend race once with time trials I made 26 passes without missing a shift So once you get it setup right with good linkage it's hard to beat.
Gus
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3...??? [Re: fourgearsavoy] #1698268
11/16/14 11:33 PM
11/16/14 11:33 PM
Rittman Ohio
Rittman Ohio
Here's a pic of the steel mounting bracket that I use with my Supershifter.
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3...??? [Re: fourgearsavoy] #1698269
11/16/14 11:39 PM
11/16/14 11:39 PM
Rittman Ohio
Rittman Ohio
Here's a pic of that B-body adaptor kit that was used to move the shifter up and back. I think it was NOS and practicality gave it away for $250.00 years ago.
Gus
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3...??? [Re: fourgearsavoy] #1698270
11/16/14 11:49 PM
11/16/14 11:49 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I ran a Hurst super shifter 3 on my 65 Olds 442. Very tight shifter. Those fat, straight rods really give you a positive feel. WAY tighter than a comp plus or stock pistol grip. You do have to cut the floor because the rods don't t have dog legs. Absolutely loved it and wish I'd never sold it. If I were building a 4 speed car I'd put one it it.
I’m listening.
Re: Hurst Super Shifter 3...??? [Re: Pale_Roader] #1698271
11/17/14 01:02 AM
11/17/14 01:02 AM
USA
Hooligan Offline
Hooligan  Offline
USA
Many years ago I grew tired of banging my knuckles on the dash of my '70 Roadrunner with that long pistol grip. Additionally, I always wanted a pistol grip equipped '70 'Cuda, but until I can marry a wealthy Mopar friendly woman, the prices are too unfriendly to me. Here's what I did... I bought a Super Shifter 3, and swapped out the 3 shifting levers for the even longer levers from the Roadrunner's pistol grip, and then bolted on a pistol grip handle from a 'Cuda to possibly produce the shortest throw Hurst shifter ever! It worked great, and other than the reverse lock-out, I did not see any special parts inside the Super Shifter 3. The large "L" bracket supplied put the pistol grip in an E-body location, so I was happy and contented. (Until the 426 Hemi bug bit me!)
Re: Hurst Super Shifter 3...??? [Re: fourgearsavoy] #1698272
11/17/14 01:07 AM
11/17/14 01:07 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Gus
Gus, is that a bracket and shift rods you made? Did you have to cut the floor?
So from the sounds of it they shift significantly better than the comp plus?
Re: Hurst Super Shifter 3...??? [Re: GTX MATT] #1698273
11/19/14 12:39 AM
11/19/14 12:39 AM
Rittman Ohio
Rittman Ohio
The bracket is from Hurst and the rods are made by me with heim joints and tubing I purchased from Liberty gears. It's not really easy making the heim joint linkage but it is rewarding and easier to adjust without messing with those spring clips. You also need to buy a left hand 3/8 24 tap
Gus
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3...??? [Re: fourgearsavoy] #1698274
11/19/14 01:06 AM
11/19/14 01:06 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Which bracket did you use?
What about the mechanism is different than the comp plus?
