New Cam Lube Alternative
#169787
12/18/08 08:22 AM
12/18/08 08:22 AM
We are all looking for additives to make our oil bullet proof. Check this out, it is a more effective additive than the I need ZDDP thought. www.camlube.com
Re: New Cam Lube Alternative
#169788
12/18/08 10:08 AM
12/18/08 10:08 AM
#169789
12/18/08 10:23 AM
12/18/08 10:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Has anyone tried this with their flat tappet cam. I've never heard of it(which means nothing) but if it was all that I believe we would have heard about it. We know that zinc was removed and thats when we seen issues and basicly they say zinc is bad. I dont know but I'll let someone try it first
[Re: 3604speed]
#169792
12/20/08 12:49 PM
12/20/08 12:49 PM
Posts: 21,833 Kirkland, Washington
Pacnorthcuda
Yes I have tried it! And I know a bunch of guys in Salt Lake, UT that tested it all last year. It truly looks like the answer to what is missing. And since it has no zinc, chlorine or teflon stuff in it, it may be around for a long time!
You think zinc additives will not be on the market for long? Why?
[Re: Pacnorthcuda]
#169793
12/20/08 01:13 PM
12/20/08 01:13 PM
Posts: 1,226 Peoples republic of clackamas ...
atoetly
Why did they remove zinc from oil in the first place? Why did they remove lead from gasoline? Probably the same people that invented the internet? I think they have been refered to as Luberals?
[Re: atoetly]
#169794
12/20/08 02:01 PM
12/20/08 02:01 PM
Pacnorthcuda
"Luberals" thats funny!!! My point is that an additive is SO "under radar" that its highly unlikely to be the target for removal from the market in its additive form. Taking out of the oil solves 99.999% of the problem due to the incredibly small minority of people that will actually put a zinc ADDITIVE in the crankcase. Tetraethyl Lead was removed (I think?--maybe you can still buy it as an additive?) but that was a pretty visable issue (Lead is poison that everyone equates to ruining our children's lives), I don't think the 'zinc kills catalytic converters over time and therefor leads to more pollution from high mileage cars' is in the same league in terms a problem that needs to be addressed.
I would bet that zinc additive will be on the market for some time, and likely more will even be introduced. Moly (Comp Cams additive is Moly) works too.
[Re: B5 Bee]
#169801
12/21/08 03:59 AM
12/21/08 03:59 AM
Posts: 53 New Mexico
3604speed
New Mexico
Maybe these guys have something new that works? I am always open to a new "Mouse Trap". After all, we did through away the stone tables a while back for something Al Gore supposedly invented called the internet. And being a Curious George I found this as an excerpt from a ZDDP study. "The results described show that ZDDP reaction films can produce high friction in intermediate speed conditions even when the films formed are quite smooth. Thus reaction film roughness is not the main origin of the friction-enhancing effect. Instead the effect appears to be due to reduced lubricant entrainment when a ZDDP reaction film is present on one of the rubbing surfaces. CONCLUSION: ZDDP reaction films formed in rubbing contacts are known to produce enhanced friction in mixed lubrication conditions. In previous work this has been ascribed to a roughening of the surfaces due to the reaction film. However the current work shows that this is not the case; instead the ZDDP reaction film appears to inhibit lubricant entrainment into the contact, thereby leading to a reduced EHD film thickness compared to ZDDP-free lubricants." So my thought is if these guys have found a way to supply protection with out adding friction, just maybe it is worth a look. We are all looking for help here. I am not looking for any kind of an argument here, we just need to keep an open mind. Their web site is very interesting and brings up some good points to consider.
[Re: 3604speed]
#169802
12/21/08 12:49 PM
12/21/08 12:49 PM
Pacnorthcuda
ZDDP is outlawed in Canada and Europe. I have heard that it is on the chopping block for the US too. I like the fact that this is a product that is environmentally good to use.
You sure about this? We build trucks in the States that ship all over the world, in Ste. Therese Ontario, and in the Netherlands (DAF) that use Chevron Delo 15w40LE CJ-4 that still very much has ZDDP in it. ZDDP is still in the oils (we all know that) just at reduced levels. Are you saying Canada has banned it as a do-it-yourself additive? Can you buy STP in Canada? That still has it and its an additive....
[Re: Pacnorthcuda]
#169804
12/21/08 09:41 PM
12/21/08 09:41 PM
3604speed
New Mexico
When I was at PRI last week, the catalog suppliers were talking about the sale of ZPPP and Chlorine products not being sold in Canada. It was the first that I had heard it mentioned. The Wholesalers might be ahead of us "Users" on the information food chain. I am also not opposed to ZDDP. What I am opposed to is having to redo a fresh overhaul. I got my hands on some of this Cam Lube from the guys in Salt Lake that had access to the product for testing. My engine oil temp dropped about 15 degrees and my solid lifter cam became noticeably quieter. The guys in Salt Lake were having to do way less valve adjustments and all of their engine oil temps were 10 to 20 degrees lower. I tried it. I liked it. I see a slight improvement in performance. I will use it in my #s matching 360 Roadrunner I have to start up this winter. Somebody ask if anybody had used it and I have. I am just passing along info.
