Drag Radials vs. DOT slicks #1697861
11/11/14 11:24 PM
11/11/14 11:24 PM
WI
jcl005 Offline OP
jcl005  Offline OP
WI
hi do any of you guys know what would be the best drag radial tires. How wide can get them, and what is the traction compared to a DOT bias-ply tire.
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697862
11/12/14 02:05 AM
11/12/14 02:05 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
these
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Drag Radials vs. DOT slicks [Re: 72N96RR] #1697863
11/12/14 02:06 AM
11/12/14 02:06 AM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
or these
Re: Drag Radials vs. DOT slicks [Re: 72N96RR] #1697864
11/12/14 02:07 AM
11/12/14 02:07 AM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
the bottom one only comes in 275-60 / 15.....
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697865
11/12/14 03:29 AM
11/12/14 03:29 AM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Yes the M/T are awesome. Insanely good compared to any "normal" tire. Guys are running 6 seconds on em or even faster lol.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697866
11/12/14 04:42 AM
11/12/14 04:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
I have ran both types of M/T ET Street tires, Radials and bias ply of the same size on the street and at the strip. The bias plys work better on marginal surfaces like most streets, the radials are faster on a good track If you don't mind having the radials spin on the street, mine have gone sideways at 65 MPH passing a car on the street then go for them, if not stick with the bias plys
Re: Drag Radials vs. DOT slicks [Re: 72N96RR] #1697867
11/12/14 08:48 AM
11/12/14 08:48 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think that is the ET Street Radial? No? Comes in like 10 sizes.
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697868
11/12/14 02:48 PM
11/12/14 02:48 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
What other information such as; the kind of car, weight, stick or auto, etc.?
Re: Drag Radials vs. DOT slicks [Re: cruzin] #1697869
11/12/14 06:08 PM
11/12/14 06:08 PM
WI
jcl005 Offline OP
jcl005  Offline OP
WI
69 charger 526" 4.10dana auto w\3500 & T-brake..it's heavy 3900+, it sure is a blast to drive on the street. But, Im looking for more traction.
Also, how can I get rid of some weight and keep it a street car?
Thanks for your time!
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697870
11/12/14 08:17 PM
11/12/14 08:17 PM
M/t drag radials here too i don't run them on the street though they're just to damn sticky and pick up everything on the road..but they hook great at the track...
Re: Drag Radials vs. DOT slicks #1697871
11/12/14 10:45 PM
11/12/14 10:45 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have ET Street radials, and don't like to run them on the street too much. As said above, they pick up every small pebble you run over and throw them at your car. Also, If you're looking for street traction, I find that when they're inflated to street psi levels, they don't hook much better than a standard radial. But get them down around 20 psi, so they have some flex, and they work great.
Re: Drag Radials vs. DOT slicks [Re: BSB67] #1697872
11/13/14 01:10 PM
11/13/14 01:10 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Yeah I have those in 325-50-15s. Work great.
codfish
Re: Drag Radials vs. DOT slicks [Re: jcl005] #1697873
11/13/14 01:40 PM
11/13/14 01:40 PM
Massachusetts
Roadster Offline
Roadster  Offline
Massachusetts
WOW --- This is a loaded question for my two penny's I and my son both run radial drag slick's (Hoosier on his M/T on mine) on our NHRA Stocker's as well as every other guy in Stock Eliminator unless it is a Stick car then some of the guy's run Bias Slick's - on my Pro Street Car I have M/T Radial DOT Slicks and they work well but there are a lot of question's you should answer before making a purchase as they are not cheap - Just my two cent's
Re: Drag Radials vs. DOT slicks [Re: Roadster] #1697874
11/13/14 02:40 PM
11/13/14 02:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
how do those street radials pass an inspection for a street car?? that's why I've been leaning towards the sportsman s/r series but the size I need is $100 more per tire!
Re: Drag Radials vs. DOT slicks [Re: mikemee1331] #1697875
11/13/14 03:48 PM
11/13/14 03:48 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just go with Hoosier QTP's they are great street/
strip tires and DOT approved. Many sizes.
Snap your neck, mega G-force launch, is all I want!
Re: Drag Radials vs. DOT slicks [Re: BDS871Cuda] #1697876
11/13/14 04:17 PM
11/13/14 04:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same question, how can they pass inspection? DOT approved does not mean legal for street use. not all of us use 'antique' plates that exempt from inspection.
Re: Drag Radials vs. DOT slicks [Re: mikemee1331] #1697877
11/14/14 02:03 AM
11/14/14 02:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use Hoosier radial slicks 30 x 9 and I drive on the street with them also. I have been driving on the street with them for almost 4 years and they hook good for me at the track. My suspension is just SS springs. Ron
Re: Drag Radials vs. DOT slicks [Re: 383man] #1697878
11/14/14 02:05 AM
11/14/14 02:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
By the way the Hoosier Quick Time Pro tires are a bias tire. Ron
