Re: 5lug D60 in a Ramcharger??
[Re: RODHALL]
#1697830
11/12/14 11:53 PM
11/12/14 11:53 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
the only thing I have ever seen have a 5lug dana 60 in was a mid 60's ford half ton truck...
The D60-2 is a 5 on 5 1/2" D60 that came under early '70s Jeep J series trucks. I have a couple; 35 spline, semi float axles.
[Re: RODHALL]
#1697833
11/13/14 02:51 AM
11/13/14 02:51 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
those & Jeep & I think International pickups too
All had 5 X 5 1/2
[Re: BulletBob]
#1697834
11/13/14 03:00 AM
11/13/14 03:00 AM
Posts: 2,042 colorado
savoy64
colorado
that has a 9.25 in it----the rear cover looks a little like a dana 60 cover----i saw that green ramcharger on craigs---did you get it?
[Re: Cooter]
#1697836
11/13/14 05:26 AM
11/13/14 05:26 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have one of those 5 lug Dana 60-2 in my shop right now. It came out of a Jeep Gladiator truck. I built it for my '87 D100. I cut one tube 6" and the corresponding axle 6" and had it resplined (stock 35 spline!) and reassembled with all stock parts (12" drum brakes) and it will virtually bolt into my truck. With 16" wheels @ 5 on 5.5" bolt circle I could put it into a Duster (A-body width)
They (Jeep Gladiators) are not that rare...there is one being used as a sign board at a tire shop on Meridian and another for sale 1/2 mile south on the other side of the highway.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 76dodgeboy]
#1697846
11/16/14 06:04 PM
11/16/14 06:04 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Are you sure that isn't a Dana 44?
1970 Dodge d100/eventually going on a 77 D100 frame
