Re: Rust repair help [Re: jbc426] #169767
12/25/08 10:51 AM
12/25/08 10:51 AM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
If done right it WILL last for years. Duct tape and Allmetal AIN'T the right way to fix it, but I'll bet he knows that.
Come on now, you DO remove the duct tape once the Almetal hardens, and no it's not the "right" way, but it does work rather well. It's hard to argue the speed, cost, durability and appropriateness for those who don't have the means or the money for the "right" way. Not everyone can afford fancy metal work and/or expensive tools.
Well, he did ask for "the best approach" to fix his rust problem, not the cheapest way.
And I agree that not everyone has access to the needed tools or the funds to pay a professional.
Merry Christmas!
Re: Rust repair help [Re: jbc426] #169768
12/25/08 12:49 PM
12/25/08 12:49 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Clean all the primer and rust off it, put some duct tape on the back side to plug the holes, and skim a coat of Almetal on it. Block it, prime it and do your finish work. You can do it and the body seam at the same time. Once finished, 99.999% of people would never know the difference, and if done right it would last for years.
Re: Rust repair help [Re: JDMopar] #169769
12/27/08 07:54 AM
12/27/08 07:54 AM
Michgian
moparfun340 Offline
moparfun340  Offline
Michgian
What is almetal is it some kind of bondo. Where is the best place to get it? If I have a spot like that should I get it media blasted first to make it last longer. About how long do you THINK it will last.
Re: Rust repair help [Re: moparfun340] #169770
12/27/08 10:12 AM
12/27/08 10:12 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It is a two-part catalyzed bondo-like product with a silver metal powder instead of the plastic filler. Used sparingly, it's actually a very good product for it's intended use. It's available at any auto paint store or over the net.
It's important to clean and remove any unsound material, treat the rust with a rust converting product and once the almetal is in place and shaped, to seal it well, so it is protected from air and moisture. If done properly, it will last as long as your paint job. If you live in an area where they salt the roads, you have a lot of chalenges to keep your car in rust free condition as it is. I feel sorry for those who have to fight that battle. These cars are hard enough to restore without fighting and repairing the problems that rust brings to the table.
The correct way is always to cut out the bad spot and weld in fresh clean metal, but depending on what your trying to do and what you're working with. That might not be the best way in your case.
Re: Rust repair help [Re: jbc426] #169771
12/27/08 10:27 AM
12/27/08 10:27 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Re: Rust repair help [Re: 5carguy] #169772
12/27/08 11:19 AM
12/27/08 11:19 AM
Michgian
moparfun340 Offline
moparfun340  Offline
Michgian
Will duraglass work as good at the almetal. Is that the real name for it almetal or is it something else. Plus do you think evapo rust is a good thing to use after media blasting the spot?
Re: Rust repair help [Re: BarrsRestoration] #169773
12/27/08 12:18 PM
12/27/08 12:18 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Make a patch panel for it or just the area where the is actual hole through then lead fill the rest since your right at the seem...
Steve
