Rust repair help #169747
12/18/08 02:39 AM
12/18/08 02:39 AM
NorCal, USA
8
8Cuda Offline OP
8Cuda  Offline OP
NorCal, USA
What would be the best approach to repair the rusted areas of my quarter panels on my 70 Cuda 440?
Re: Rust repair help [Re: 8Cuda] #169748
12/18/08 02:58 AM
12/18/08 02:58 AM
Middleton, ID
curleysracecars Offline
Middleton, ID
Best approach I would say is to hang a new quarter panel on it. You could make a panel that fits in their after cutting the rusted spots out, but it would take someone who had some metal forming skills. If you have these skills, go for it.
Kyle
Kyle Curley
Re: Rust repair help [Re: curleysracecars] #169749
12/18/08 04:01 AM
12/18/08 04:01 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If that is all the rust that you have I would make a patch panel rather than replace the whole thing.
Re: Rust repair help [Re: Morty426] #169750
12/18/08 08:05 AM
12/18/08 08:05 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Will a vinyl top be going back on?
I would be tempted to hold a disimilar metal behind the hole, while you fill each small hole with a mig welder.
CUt the area out and patch if the mig only makes the holes bigger.
I would only try to fill the holes like this if the entire panel is fine except the area in the photo.
Re: Rust repair help [Re: Finoke] #169751
12/18/08 08:27 AM
12/18/08 08:27 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Youll never fill those holes with a mig. Your just going to make them bigger trying and then you still have rust pits to deal with. Cut it out and replace it is the correct way to fix it.
Re: Rust repair help [Re: 8Cuda] #169752
12/18/08 09:14 AM
12/18/08 09:14 AM
Jacksonville Florida
elitecustombody Offline
one of my tricks is before you cut it out, make patch panel,while beating and shaping it,keep laying it over the problem are to get the right shape and curvature,once you know the patch panel lays nice and flat up against the old pitted spot,trace out cut line and proceed with cutting the rusted out metal then weld a new patch in, it will help you to keep filler to a minimum, good old English wheel would come in handy,but if you have no access to sheetmetal forming equipment, few hammers and a block of wood will do
good luck
Stefan
Re: Rust repair help [Re: elitecustombody] #169753
12/18/08 09:50 AM
12/18/08 09:50 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
good luck
Stefan
and since you're in Cali I suspect the rest of the panel is in decent shape. I'd simply replace the area. If a vinyl top is going back on don't assume it's going to hide imperfections. You'd be surprised how imperfect shaping will show thru a top.
Re: Rust repair help [Re: Quikshft] #169754
12/18/08 12:06 PM
12/18/08 12:06 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yep, cut it out and replace with a patch. If you don't have the skills to make the patch, look around for a good metal guy. Even a good HVAC shop guy could make one.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Rust repair help [Re: 8Cuda] #169755
12/18/08 12:07 PM
12/18/08 12:07 PM
my suggestion- Find someone who is restoring a Cuda convertible,and get the unused upper 1/4 from a reproduction full 1/4 like those that AMD makes.
Or just buy an AMD full 1/4 ,cut off the part you need,and sell the 1/4 to a convertible owner
Re: Rust repair help #169756
12/18/08 04:44 PM
12/18/08 04:44 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Perhaps a great candidate for that zinc spray process........
If you have somebody near that does it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Rust repair help [Re: CJK440] #169757
12/19/08 10:18 AM
12/19/08 10:18 AM
Detroit, MI
FC7AARcuda Offline
FC7AARcuda  Offline
Detroit, MI
With all the people now replacing their quarters with the new full panels, you should be able to find someone who has this section from the old panel they removed. Try placing an ad in the E-body parts wanted section.
Re: Rust repair help [Re: 8Cuda] #169758
12/20/08 11:45 PM
12/20/08 11:45 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
This is what I did to fix the same problem, and it was a '70 6-pack car, too!
http://www.clarkclassic.com/mygallery/index.asp?CatID=33
Steve
Re: Rust repair help [Re: BarrsRestoration] #169759
12/21/08 02:56 PM
12/21/08 02:56 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Steve
Man...that sure is a nice lookin Whirly Jig!
Re: Rust repair help [Re: JDMopar] #169760
12/21/08 03:13 PM
12/21/08 03:13 PM
Greenville, N.C.
Greenville, N.C.
Yeah, it was. Someone from Asheville ended up buying it.
Re: Rust repair help [Re: CJK440] #169761
12/21/08 06:54 PM
12/21/08 06:54 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
i agree a member here at moparts mr.b think in ohio does it or at least he used to also does polishing and plating of trim now
he has pics of this sray welder system.looks like it works great when you can blast the metal clean on both sides then fill
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Rust repair help [Re: 8Cuda] #169762
12/24/08 03:21 PM
12/24/08 03:21 PM
GMP440 Offline
GMP440  Offline
If that's the only bad area, just replace that piece
Re: Rust repair help [Re: 8Cuda] #169763
12/24/08 09:16 PM
12/24/08 09:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Clean all the primer and rust off it, put some duct tape on the back side to plug the holes, and skim a coat of Almetal on it. Block it, prime it and do your finish work. You can do it and the body seam at the same time. Once finished, 99.999% of people would never know the difference, and if done right it would last for years.
Re: Rust repair help [Re: jbc426] #169764
12/24/08 11:09 PM
12/24/08 11:09 PM
Greenville, N.C.
Greenville, N.C.
If done right it WILL last for years. Duct tape and Allmetal AIN'T the right way to fix it, but I'll bet he knows that.
Re: Rust repair help [Re: jbc426] #169765
12/25/08 03:07 AM
12/25/08 03:07 AM
DPelletier Offline
DPelletier  Offline
Re: Rust repair help [Re: BarrsRestoration] #169766
12/25/08 04:19 AM
12/25/08 04:19 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Come on now, you DO remove the duct tape once the Almetal hardens, and no it's not the "right" way, but it does work rather well. It's hard to argue the speed, cost, durability and appropriateness for those who don't have the means or the money for the "right" way. Not everyone can afford fancy metal work and/or expensive tools.
