$128! 2001 CTD oil pressure sender switch
#1697408
11/11/14 03:12 AM
11/11/14 03:12 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Looks like the oil pressure sender switch is bad in my new rig, as it reads 80 psi when not running.
Looking on RockAuto, they are $128- for a sender switch.
Am I missing something here, or is this nuts? The switch looks pretty basic.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: $128! 2001 CTD oil pressure sender switch
[Re: stumpy]
#1697410
11/11/14 04:39 PM
11/11/14 04:39 PM
EWJ
Back in NJ....
Not yet: in seeing that MoparMan1973 had a section regarding this sender unit in his 2nd Gen 24V webpage, I figured it was a common failure/issue.
I will do that however- thanks Stumpy.
[Re: EWJ]
#1697411
11/11/14 06:59 PM
11/11/14 06:59 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I'm not sure exactly what year Ma started doing this but I know at some point the sender just became an on off switch and the gauge was controlled by software to read what it should be, at whatever temp and rpm. No actual input from the sender.
[Re: 71yelladustr]
#1697413
11/12/14 01:30 AM
11/12/14 01:30 AM
EWJ
Back in NJ....
Thanks for the info and tip regarding Genos!
