$128! 2001 CTD oil pressure sender switch #1697408
11/11/14 03:12 AM
11/11/14 03:12 AM
Back in NJ....
E
EWJ Offline OP
EWJ  Offline OP
E
Back in NJ....
Looks like the oil pressure sender switch is bad in my new rig, as it reads 80 psi when not running.
Looking on RockAuto, they are $128- for a sender switch.
Am I missing something here, or is this nuts? The switch looks pretty basic.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: $128! 2001 CTD oil pressure sender switch [Re: EWJ] #1697409
11/11/14 02:55 PM
11/11/14 02:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Foolish question. did you unplug the sender and check to see what the gauge read?
Re: $128! 2001 CTD oil pressure sender switch [Re: stumpy] #1697410
11/11/14 04:39 PM
11/11/14 04:39 PM
Back in NJ....
E
EWJ Offline OP
EWJ  Offline OP
E
Back in NJ....
Not yet: in seeing that MoparMan1973 had a section regarding this sender unit in his 2nd Gen 24V webpage, I figured it was a common failure/issue.
I will do that however- thanks Stumpy.
Ed
Re: $128! 2001 CTD oil pressure sender switch [Re: EWJ] #1697411
11/11/14 06:59 PM
11/11/14 06:59 PM
Guitar Jones Offline
I'm not sure exactly what year Ma started doing this but I know at some point the sender just became an on off switch and the gauge was controlled by software to read what it should be, at whatever temp and rpm. No actual input from the sender.
Re: $128! 2001 CTD oil pressure sender switch [Re: Guitar Jones] #1697412
11/12/14 12:32 AM
11/12/14 12:32 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Guitar is right about the virtual oil pressure gauge on your CTD. They went to that crap when the 24V came out in 98 1/2. Genos garage has the sending units for $87.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: $128! 2001 CTD oil pressure sender switch [Re: 71yelladustr] #1697413
11/12/14 01:30 AM
11/12/14 01:30 AM
Back in NJ....
E
EWJ Offline OP
EWJ  Offline OP
E
Back in NJ....
Thanks for the info and tip regarding Genos!
Ed
Re: $128! 2001 CTD oil pressure sender switch [Re: EWJ] #1697414
11/18/14 11:48 PM
11/18/14 11:48 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
also if you have a Cummins dealer close they are cheaper to buy parts from than Dodge dealers..
Re: $128! 2001 CTD oil pressure sender switch [Re: rumblebee4232] #1697415
11/19/14 02:38 AM
11/19/14 02:38 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I replaced that in my 2000 ram. It was $400 all said and done.
Boy I miss that truck
