How to fix the threads? #1697321
11/10/14 11:16 PM
11/10/14 11:16 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
There are 2 bolts holding my ignition box to the firewall. One of the holes is stripped as the bolt wont tighten and it needs to be tight for a good ground, how can i fix this being the firewall metal is so thin..?
Re: How to fix the threads? [Re: mopower440] #1697322
11/10/14 11:30 PM
11/10/14 11:30 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I use nut inserts. Various sizes available. Work great for holding a mirror on the body of a car. McMaster-Carr
Google nut inserts as there are YouTube vidoes on how to install them.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: How to fix the threads? [Re: mopower440] #1697323
11/10/14 11:48 PM
11/10/14 11:48 PM
the next size up Metric bolt might do it, jamb it in there & with that, slightly file the hole (as needed). EDIT better/more professional might be to run a metric tap in there & get it dead on, wouldn't take but a minute or two
Re: How to fix the threads? [Re: RapidRobert] #1697324
11/11/14 12:27 AM
11/11/14 12:27 AM
moparx Online content
moparx  Online Content
check your local hardware store also. anymore, most have an "automotive" bin in their "nutz-n-boltz" section. if they do, most have nutserts and a cheapy installation tool for them as well as oversize factory style screws.
Re: How to fix the threads? [Re: moparx] #1697325
11/11/14 12:58 AM
11/11/14 12:58 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The same thing happened to me. The original screws have a finer thread then a regular sheet metal screw. I was able to put a nut on the back side and get it nice and tight. This was on a Challenger so I could reach right in through the cowl vent hole.
Re: How to fix the threads? [Re: burdar] #1697326
11/11/14 01:05 AM
11/11/14 01:05 AM
BDW Offline
BDW  Offline
Same here, ammeter was jumping all over the place. Once I figured out it was the loose bolts, nut on the other side fixed it.
Re: How to fix the threads? [Re: BDW] #1697327
11/11/14 05:09 AM
11/11/14 05:09 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For stripped screws in sheet metal, put a bent piece of wire in the hole and re-try the screw. You can also use a piece of nylon fishing line.
Re: How to fix the threads? [Re: kentj340] #1697328
11/12/14 11:45 AM
11/12/14 11:45 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have used .030 Mig wire single or doubled if it is really too big, works fine and helps the electrical contact.
cut an inch of wire, make a V out of it, put one end in the hole and the other outside the hole. That takes up the extra room.
Re: How to fix the threads? [Re: sthemi] #1697329
11/12/14 11:11 PM
11/12/14 11:11 PM
IN
ahy Offline
ahy  Offline
IN
Another solution is a bigger screw. The AP store will likely have hex head body fastener, about the same size you have, with 1/4" threads.
Re: How to fix the threads? [Re: mopower440] #1697330
11/13/14 12:59 AM
11/13/14 12:59 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Is this in the firewall of the pictured dirt track car?Move it sideways or up/down and drill 2 brand new holes.Or just run the screws in and let them make the new holes.
Re: How to fix the threads? [Re: 67_Satellite] #1697331
11/13/14 01:04 AM
11/13/14 01:04 AM
middle Tennessee
middle Tennessee
No, not in the dirt car, its in my dart, dont really want to drill any holes in her anywhere..
Re: How to fix the threads? [Re: Dads426] #1697332
11/30/14 10:13 PM
11/30/14 10:13 PM
middle Tennessee
middle Tennessee
Can you tell me what size nut inserts i need to get for this?
Re: How to fix the threads? [Re: mopower440] #1697333
12/01/14 12:33 AM
12/01/14 12:33 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The original bolt size was likely close to 1/4" x 20 thread count. I would probably go for that size, and use new bolts when installing the box. Gene
Re: How to fix the threads? [Re: poorboy] #1697334
12/13/14 08:41 PM
12/13/14 08:41 PM
middle Tennessee
middle Tennessee
well the rivet nuts were a COMPLETE FAILURE!! Now i got a mess from hell. Dont see how they are of any use. I installed the damn things and went to tighten the bolts up when mounting the ECU and the stupid rivet nuts turned! They refuse to grip the sheet metal enough to tighten much at all. I had to grab them with a pair of dykes and rip them out of the firewall. Now i am screwed.
Re: How to fix the threads? [Re: mopower440] #1697335
12/13/14 08:46 PM
12/13/14 08:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That sucks , there are better choices than the one you ended up using , but I'm sure that was all you could find in a local hardware store , but you should have drilled it out and not ripped it out , but I understand the frustration.
What does the firewall look like now ?
Re: How to fix the threads? [Re: JohnRR] #1697336
12/13/14 09:13 PM
12/13/14 09:13 PM
middle Tennessee
middle Tennessee
well, i managed to play around with the holes in the firewall and got them beat down to where they would fit another rivet nut but whats the point if they dont work..I dont see how or why anyone uses these since you cant go past finger tight...? I didnt buy the rivet nuts or the tool. A guy at work had it. When i installed the first one it spun real easy, so i re-set it with the tool with a lot more pressure and snapped the handle in half on his tool and had to buy him a new one and it was not cheap! It was a marson thread setter brand. Like i said, if i put that much pressure to break the damn tool and the rivet nut cant grab any better than that, then why do people use them..?
Re: How to fix the threads? [Re: mopower440] #1697337
12/13/14 09:45 PM
12/13/14 09:45 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Bummer about your experience. I've used rivnuts in mopar EOM sheetmetal with zero probs.
Re: How to fix the threads? [Re: Vert] #1697338
12/13/14 10:34 PM
12/13/14 10:34 PM
middle Tennessee
middle Tennessee
Really? What do you think went wrong? I see people using them on the internet all the time, i dont understand why these didnt work worth a crap..? Is it because they are hex-shaped? Most i see are round..
Re: How to fix the threads? [Re: mopower440] #1697339
12/13/14 10:59 PM
12/13/14 10:59 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Re: How to fix the threads? [Re: mopower440] #1697340
12/13/14 11:12 PM
12/13/14 11:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rivnuts are pretty common in OE applications. Mercedes and Porsche use them all over their cars. They hold on all kinds of body panels and electrical components.
Maybe your installation wasn't tight enough due to a poor quality nut or poor installation. It's easy to get 'em off a bit if you're using a nut and bolt for installation.
This video has a good look at installation.
https://www.youtube.com/v/KeaMsvai0FA
- Stu Harmon
