Re: How to fix the threads?
[Re: mopower440]
#1697322
11/10/14 11:30 PM
11/10/14 11:30 PM
Posts: 1,443 Maryland
Dads426
Maryland
I use nut inserts. Various sizes available. Work great for holding a mirror on the body of a car. McMaster-Carr Google nut inserts as there are YouTube vidoes on how to install them.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: mopower440]
#1697323
11/10/14 11:48 PM
11/10/14 11:48 PM
RapidRobert
the next size up Metric bolt might do it, jamb it in there & with that, slightly file the hole (as needed). EDIT better/more professional might be to run a metric tap in there & get it dead on, wouldn't take but a minute or two
[Re: burdar]
#1697326
11/11/14 01:05 AM
11/11/14 01:05 AM
Posts: 4,730 Florida
BDW
The same thing happened to me. The original screws have a finer thread then a regular sheet metal screw. I was able to put a nut on the back side and get it nice and tight. This was on a Challenger so I could reach right in through the cowl vent hole.
Same here, ammeter was jumping all over the place. Once I figured out it was the loose bolts, nut on the other side fixed it.
[Re: BDW]
#1697327
11/11/14 05:09 AM
11/11/14 05:09 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
For stripped screws in sheet metal, put a bent piece of wire in the hole and re-try the screw. You can also use a piece of nylon fishing line.
[Re: kentj340]
#1697328
11/12/14 11:45 AM
11/12/14 11:45 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I have used .030 Mig wire single or doubled if it is really too big, works fine and helps the electrical contact.
cut an inch of wire, make a V out of it, put one end in the hole and the other outside the hole. That takes up the extra room.
[Re: 67_Satellite]
#1697331
11/13/14 01:04 AM
11/13/14 01:04 AM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
Is this in the firewall of the pictured dirt track car?Move it sideways or up/down and drill 2 brand new holes.Or just run the screws in and let them make the new holes.
No, not in the dirt car, its in my dart, dont really want to drill any holes in her anywhere..
[Re: Dads426]
#1697332
11/30/14 10:13 PM
11/30/14 10:13 PM
mopower440
middle Tennessee
Can you tell me what size nut inserts i need to get for this?
[Re: mopower440]
#1697335
12/13/14 08:46 PM
12/13/14 08:46 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
well the rivet nuts were a COMPLETE FAILURE!! Now i got a mess from hell. Dont see how they are of any use. I installed the damn things and went to tighten the bolts up when mounting the ECU and the stupid rivet nuts turned! They refuse to grip the sheet metal enough to tighten much at all. I had to grab them with a pair of dykes and rip them out of the firewall. Now i am screwed.
That sucks , there are better choices than the one you ended up using , but I'm sure that was all you could find in a local hardware store , but you should have drilled it out and not ripped it out , but I understand the frustration.
What does the firewall look like now ?
[Re: JohnRR]
#1697336
12/13/14 09:13 PM
12/13/14 09:13 PM
mopower440
middle Tennessee
well, i managed to play around with the holes in the firewall and got them beat down to where they would fit another rivet nut but whats the point if they dont work..I dont see how or why anyone uses these since you cant go past finger tight...? I didnt buy the rivet nuts or the tool. A guy at work had it. When i installed the first one it spun real easy, so i re-set it with the tool with a lot more pressure and snapped the handle in half on his tool and had to buy him a new one and it was not cheap! It was a marson thread setter brand. Like i said, if i put that much pressure to break the damn tool and the rivet nut cant grab any better than that, then why do people use them..?
[Re: Vert]
#1697338
12/13/14 10:34 PM
12/13/14 10:34 PM
mopower440
middle Tennessee
Bummer about your experience. I've used rivnuts in mopar EOM sheetmetal with zero probs.
Really? What do you think went wrong? I see people using them on the internet all the time, i dont understand why these didnt work worth a crap..? Is it because they are hex-shaped? Most i see are round..
