9 inch brake setup #1697192
11/10/14 08:53 PM
11/10/14 08:53 PM
indiana
moparbrown14 Offline OP
indiana
Wanting to put 9 inch brake setup on my 74 duster looking to lose weight over our 10 inch setup what will work the drums on our 10 inch setup are heavy. Will a setup off a late 60s dart work
Re: 9 inch brake setup *DELETED* [Re: moparbrown14] #1697193
11/10/14 09:31 PM
11/10/14 09:31 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Post deleted by mac56
Re: 9 inch brake setup [Re: mac56] #1697194
11/10/14 09:36 PM
11/10/14 09:36 PM
indiana
indiana
Yes trying to go cheap as we can yes it is for a drag car
Re: 9 inch brake setup [Re: mac56] #1697195
11/10/14 09:42 PM
11/10/14 09:42 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I raced cars with drums for years 10 inch A body and 10 inch E body but when you start running faster than 110 mph depending on the length of track and turn outs it can get interesting especially if you already used them dumping at the stripe. I recently switched over to Wilwood front disc and was happy with the front weight loss, and they work. They may not be in your budget but its a thought. also I know there are many people who have run much faster with drums its just up to you. Good luck with your decision.
Re: 9 inch brake setup [Re: joes68340s] #1697196
11/10/14 10:20 PM
11/10/14 10:20 PM
birdtracker Offline
birdtracker  Offline
So 9 inch Ford and Honda Acura TL both have the same bolt pattern. A TL centerhole is smaller. The rear disc brake setup fits on a 9 inch very nice. All you have to do is have someone open the centerhole on the rotor. I got mine from a junkyard. I got the hoses, calipers and rotors.Birdtracker
Re: 9 inch brake setup [Re: joes68340s] #1697197
11/11/14 12:04 AM
11/11/14 12:04 AM
indiana
indiana
Hey joe340s how much weight difference is there between the 10 inch and wildwood setup this is for a stocker so can't go to wild
Re: 9 inch brake setup [Re: moparbrown14] #1697198
11/11/14 03:42 AM
11/11/14 03:42 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Its been a while since the swap and I would have to guess at it. How fast are you running in the 1/4.
Re: 9 inch brake setup [Re: joes68340s] #1697199
11/11/14 04:02 AM
11/11/14 04:02 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I can tell you from recent experience that the Wildwood "pro street" front brakes weighed exactly the same as the 9" drums we removed from a 70 Duster.
Bonus: the car stops now!
Re: 9 inch brake setup [Re: cudadoug] #1697200
11/11/14 05:10 AM
11/11/14 05:10 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you really want to put 9" drums on, I have a complete setup at my shop we just took off a '70 Dart. They are not that light, and stopping with them in a hurry is a white knuckle ride for sure.
Re: 9 inch brake setup [Re: slantzilla] #1697201
11/11/14 07:36 AM
11/11/14 07:36 AM
Q
Quicktree Offline
Quicktree  Offline
Q
waste of time swapping drum brakes, if you want to save weight go to a cheap disc set up. and even they may not be that much lighter but at least you can stop
Re: 9 inch brake setup [Re: Quicktree] #1697202
11/11/14 08:10 AM
11/11/14 08:10 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I would not put 9" drums on. I just took them off my duster, and saved a ton of weight. I weighed my aerospace kit I have not weighed all my drum parts yet but I'm willing to bet it's around 25 lbs savings.
Why do you want to stay with drums? The only reason I kept them for so long was because they didn't do much for me to stop on the ice, since the rears do all the stopping. Once I hit the asphalt I had a he77 of a time stopping from 140 mph.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 9 inch brake setup [Re: moparbrown14] #1697203
11/12/14 12:28 AM
11/12/14 12:28 AM
smyrna,tn
draginmopars Offline
smyrna,tn
some weight info
(all drums pics are 1970 model)
10" drum with hub = 14 lbs
9" finned drum with hub = 12 lbs
9" smooth drum with hub = 10.5 lbs
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
