6.76 Rod options? better than Eagle/Scat. (not anymore #1697102
11/10/14 06:32 PM
11/10/14 06:32 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'd like to find a better rod than Eagle/Scat but it seems that no one is making them anymore so I wanted to see if you guys knew of any other options.
If I didn't already have the 4.15 Callies crank and Diamond pistons I'd look to change stroke or move to longer rod (Hemi) and change the pin height on a piston, but it't too late for that.
I may have no choice but to go Aluminum if I want something better than Eagle/Scat. I understand Scat is making a pretty good rod for up to 1,000hp and this motor will make less than that but it's going in my KB block and I'd rather put a better rod in it if I can find one.
No availability for any of these manufactures 6.76 w/ .990 pin:
Crower - $1,800 - no stock no plans
Oliver - $1,300 - no stock no plans
Lunati - $? - no stock no plans
Carrillo - $? - no stock no plans
Howards - $? - no stock no plans
Manley - $? - no stock no plans
Help?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697103
11/10/14 06:48 PM
11/10/14 06:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Molnar Technologies; the guy who started K1 branched out on his own again.
What size crank pin are you running?
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697104
11/10/14 06:59 PM
11/10/14 06:59 PM
gregsdart Offline
gregsdart  Offline
You can still possibly offset grind the crank to 2.200 bearing, 4.270 stroke, use the common 6.7 long 2.200 bearing x .990 pin rods. Rod availability is now good, bearings are a touch cheaper, and you have fourteen more cubes. You could possibly go to 4.25 stroke and use custom gaskets to make up the .010 minus deck height, if you want a common combo.
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: gregsdart] #1697105
11/10/14 07:54 PM
11/10/14 07:54 PM
Tulsa, Ok
Tulsa, Ok
Std Chrysler crank size, and I would rank the Molar rod with Scat. Would work just fine, just wanted a better rod.
Good info Greg, hadn't thought about that option but I hate to offset grind a good Callies crank. I'd probably just go with Aluminum rods if that's my only option
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697106
11/10/14 07:59 PM
11/10/14 07:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Alum rod may cause clearance issues in the block. Looks like you hit all the big dollar rod makers and there is nothing, did you check ebay?
Try calling Barton and a few other places to see if they have something hiding on a back shelf ?
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: JohnRR] #1697107
11/10/14 08:20 PM
11/10/14 08:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wade try this place , he lists the manley sportsmaster , also try Campbell enterprises ?
http://www.rpmrons.com/manleysteel2.html
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: JohnRR] #1697108
11/10/14 08:21 PM
11/10/14 08:21 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
I have a brand new set of 6.760 grp pro series rods if interested.. I ordered the wrong length so i would make someone a deal.
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697109
11/10/14 11:15 PM
11/10/14 11:15 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I have this set of rods why won't this work.
http://www.callies.com/compstar/connecting-rods/h-beam/
CSE6760FS3D5AH
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: JD Dart] #1697110
11/11/14 12:12 AM
11/11/14 12:12 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Call R&R. That is where I buy all my aluminum rods but they also make very nice steel rods. All 100% American made. They are billet rods and custom is no problem
Monte
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: Monte_Smith] #1697111
11/11/14 02:14 AM
11/11/14 02:14 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Howards ?
Their billet pieces look good on paper , but I have no first hand experience with them.
Sorry.
Read first....then type.
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: tubtar] #1697112
11/11/14 02:32 AM
11/11/14 02:32 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Molnar DH6760YTB8-A
Mopar to the bone!!!
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: 72Swinger] #1697113
11/11/14 12:59 PM
11/11/14 12:59 PM
BradH Offline
BradH  Offline
Molnar DH6760YTB8-A
I mentioned Molnar above, but the OP said he doesn't consider them any better than SCAT.
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: JD Dart] #1697114
11/11/14 01:10 PM
11/11/14 01:10 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
CSE6760FS3D5AH
Yep....... Compstar makes great rods, ran a set in my 422 small block. Chuck@ best machine really likes them.
675 a set, Barton sells them and they are 990 pin
Edit..... I am sure best carries them as well
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: BradH] #1697115
11/11/14 01:12 PM
11/11/14 01:12 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
We have used tons and tons of Molnar rods and I can tell you, the finished product from Molnar far exceeds the quality of Scat rods. I know they both start out as Chinese rods but the quality is much better on the Molnar and we have several sets in pretty stout bracket engines ( over 1000hp ) and I know of several sets in higher hp turbo cars. I think you'd be happy with the rods from Tom Molnar.
J.C. Childress (434) 665-9541
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: B3422W5] #1697116
11/11/14 01:15 PM
11/11/14 01:15 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Compstar Rods for sure
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: PETE@BESTMACHINE] #1697117
11/11/14 04:43 PM
11/11/14 04:43 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
http://www.autoverdi.com/rods.html
Probably the best damn steelrods you will ever find. As a bonus they are not made in asia.
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: PETE@BESTMACHINE] #1697118
11/11/14 07:28 PM
11/11/14 07:28 PM
Tulsa, Ok
Tulsa, Ok
ok, sounds like I need to re-consider Compstar and Molnar rods.
I wished Callies would make an Ultra H-Beam for Mopar, I'm hearing Chevy builders are really impressed with them and hearing that some Oliver rod are having some issues which never used to happen.
I'm only going to make 850 or less HP so I know Eagle, Scat, Molnar and Compstars would do all I need just thought I'd look into a better rod for a little more insurance and be able to run them for 3,000 passes and not worry about them (since I'm putting them in my KB block), other than to change the bolt every now and then.
Thanks for the help guys!
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697119
11/12/14 12:49 AM
11/12/14 12:49 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
pankyl ? they will make u any size for a hefty price,or possibly ohio crankshaft,
SFI 25.5 depends,no leak,even at 213 mph....
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697120
11/12/14 04:05 PM
11/12/14 04:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you really like that rod then I would do the math with the pistons you have and turn down the crank and adjust the stroke to use on of those rods, probably end up costing close to the same as a big dollar rod for a mopar journal ?
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore [Re: WadeMetzinger] #1697121
11/12/14 05:07 PM
11/12/14 05:07 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Molnar is the only one(in this price range) that will garantee that the rods he sells you will be good to "X" amount of HP. That kinda says something IMO.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
