9.25 rear axle went boom ! #1696823
11/10/14 03:40 AM
11/10/14 03:40 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Driving down the street Saturday to save my Kid who ran out of gas and when I backed off the gas pedel to stop the rear end made a loud scream, I lightly got back on the gas and it went away.. but I had to stop for the light so I took my foot off the gas then it went boom !
Screach and ground to an immediate halt...luckily not towing the trailer and the person behind me was able to stop..
Had to get it towed home...just a few blocks, looks like the pinion nut came loose and then came off.
I had to change the Power loc unit about 40K miles ago, when it blew up..and left parts everwhere, so I guess it was only me to blame...
Looks like everything is trashed, I think even the housing is junk.
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696824
11/10/14 03:41 AM
11/10/14 03:41 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Another view
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696825
11/10/14 01:59 PM
11/10/14 01:59 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
dang too bad.
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696826
11/10/14 05:02 PM
11/10/14 05:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had a long chat with the owner of a driveline shop when I went into buy a new yoke for my Dana 60. He showed me a new style pinion nut that fit the 9.25 and Dana 60 and was the latest and greatest. It was less than $20.00 so I bought it and added it to my build. This was at least 2 years ago. 9.25s have a history of pinion nut problems...almost 30 years ago I saw first hand how the loss of a pinion nut caused a truck to flip. You were very lucky
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696827
11/10/14 05:50 PM
11/10/14 05:50 PM
Guitar Jones Offline
I'd tighten it back up and keep going.
OK, seriously, glad no one was hurt, that could have been ugly.
Re: 9.25 rear axle went boom ! [Re: Guitar Jones] #1696828
11/10/14 07:43 PM
11/10/14 07:43 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Not going to happen, I actually tried that, just to get it mobile on my drivway... it is trashed. moved a couple of inches and locks up again.
Re: 9.25 rear axle went boom ! [Re: Polarapete] #1696829
11/10/14 11:54 PM
11/10/14 11:54 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Do you have the P/N?
Re: 9.25 rear axle went boom ! [Re: WO23Coronet] #1696830
11/11/14 06:16 PM
11/11/14 06:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
When my pinion nut came loose I could hear a high pitched whine on deceleration and knew something was up, tightened it up and no issues a year later. I would expect it to give some warning if a person pays any attention to such things.
Re: 9.25 rear axle went boom ! [Re: HotRodDave] #1696831
11/13/14 07:57 PM
11/13/14 07:57 PM
dogdays Offline
dogdays  Offline
There's a reason the cover looks like a Stop sign!
R.
Re: 9.25 rear axle went boom ! [Re: dogdays] #1696832
11/13/14 11:53 PM
11/13/14 11:53 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think it is a good idea to ditch the crush sleeve too.....
Re: 9.25 rear axle went boom ! [Re: savoy64] #1696833
11/16/14 03:27 PM
11/16/14 03:27 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
The crush sleeve eliminator looks like an easy upgrade. I do tow the trailer a lot.
I got the old rear end out and taken apart, it looks like the housing is damaged pretty bad, I think It will need another housing.
There is a lot of damage around the bearing areas and a ding that is almost broken thru the bottom of the housing.
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696834
11/16/14 04:12 PM
11/16/14 04:12 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That wasn't the Warlock, was it?
JB Rhinehart, Realist
A-Body's RULE!
Re: 9.25 rear axle went boom ! [Re: Rhinodart] #1696835
11/16/14 04:52 PM
11/16/14 04:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Newer truck Jim. It has the trigger ring for speed/abs..
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696836
11/16/14 08:58 PM
11/16/14 08:58 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
i have a complete recently overhauled 9.25 rear axle from my 2000 1500 quadcab that got t boned a few months ago .
It has 77k miles on the factory 3.55 gears and housing with all new bearings ,seals and clutch plates in the factory traclok.......i,m on the south side near oaklawn ...... if your interested send me a p.m.
Re: 9.25 rear axle went boom ! [Re: ChinooK440] #1696837
11/16/14 09:32 PM
11/16/14 09:32 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I thought so. I have a complete rear assy with a 3.91 gear sitting in my storage, took it in on trade. I believe it was out of a 2001 truck, but really haven't looked at it too thoroughly.
A-Body's RULE!
Re: 9.25 rear axle went boom ! [Re: Rhinodart] #1696838
11/17/14 03:58 AM
11/17/14 03:58 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks Jim,
Not the Warlock, I blew out the pinion gears on that one 2 years ago, it is fixed and working great...( knock on steel).
It is my black 01 Ram Off Road truck... I will call you tomorrow night..
Re: 9.25 rear axle went boom ! [Re: sthemi] #1696839
11/17/14 08:07 PM
11/17/14 08:07 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The "off road" package came with 4.10 gears.
