Finally got one semi decent run on it. #1696406
11/09/14 02:53 AM
11/09/14 02:53 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Went to Tulsa today for the Mopars at the Park. Weather wasn't too bad. Temp was mid to upper 50's and the wind was out of the N/NW at about 10 to 15 mph. The car weighs 2550 with me in it. I'm still not comfortable with it.
The run: 60'=1.417 330'=4.123 1/8=6.367 mph=108.84
1/4=9.994 mph=138.47
I'm relieved to get the 9 sec pass. I think if should 60' better. The mph seems pretty good to me at that et. Any comments? Jim
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696407
11/09/14 03:21 AM
11/09/14 03:21 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Those are about the numbers I've been running in the good air.
Same 60' a bit quicker in the 1/8 and same 1/4 ET but only 133 MPH so your really making steam on the top end. At 138 I think you have quite a bit of ET improvement left.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Finally got one semi decent run on it. [Re: DragDart360] #1696408
11/09/14 03:58 AM
11/09/14 03:58 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Fantastic MPH for that ET. Heck my 9.91 pass was only 131 mph but with my small 550 lift solid cam and 4:88 gears my engine (408) is running out of snuff for the last 300 plus feet.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Finally got one semi decent run on it. [Re: pittsburghracer] #1696409
11/09/14 04:00 AM
11/09/14 04:00 AM
Q
Quicktree Offline
Quicktree  Offline
Q
congrats you have a lot more in it at that mph
Re: Finally got one semi decent run on it. [Re: Quicktree] #1696410
11/09/14 03:05 PM
11/09/14 03:05 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I'm thinking the reason for the big MPH. Is the A/D of the body. Car didn't spin the tires when it left. According to a friend observing the run. So where do I start looking for 60' ET.
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696411
11/09/14 04:05 PM
11/09/14 04:05 PM
PA.
"Little"John
"Little"John
PA.
If you get a chance post your entire engine combo, transmission type, rear gear, and convertor stall. the more info the more guys can help.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Finally got one semi decent run on it. [Re: pittsburghracer] #1696412
11/09/14 07:19 PM
11/09/14 07:19 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
The motor: 11.2:1, W2's ported by RyanJ, Victor W2 w/PF950HP, Cam is a MP 590 [Email]265@050[/Email] w/1.6 MP roller rockers, 17/8" x 31/2" chassis headers
The trans: 727 w/TA 8" converter if flashes 5400 rev man VB
83/4 rear w/4.30 spool MW caps and axles, 11.5x29.5W slicks (95"of rollout)
Car weighs 2550 w/driver.
This drive train has been in 3 different bodies now.
1: 69 Dart street car full interior. 3500lbs/driver 4.30 gear 9x29 slicks. Best ET & MPH 11.18@119
2: 69 Dart caged race car. 3225lbs w/driver 4.56 gear 12x29 slicks. Best ET & MPH 10.50@125
3: Current combo.
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696413
11/09/14 08:01 PM
11/09/14 08:01 PM
PA.
"Little"John
"Little"John
PA.
That 60' is WAY off. Was the cam degreed in as the numbers look almost like the cam is retarded. That's a lot bigger cam than mine especially when your do the 1.6 rocker calculation.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696414
11/09/14 10:49 PM
11/09/14 10:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Nice new bests. That car with its MPH is a strong 9.75 car
I agree that the 60 doesn't match the MPH. It should be around a 1.34/5 or so.
Also your picking up 30 MPH on the second half, that's excellent. The lost 670 could be in the carbs transition circuit or it could be a cam timing issue. Since you not spinning the tires Id start there.
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696415
11/09/14 11:02 PM
11/09/14 11:02 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
A small block in a light weight car is my favorite package, so easy to work on too. What cubic inch is the motor?
Re: Finally got one semi decent run on it. [Re: ProSport] #1696416
11/10/14 12:26 AM
11/10/14 12:26 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
John, the cam is in at 106*.
Sport440, I only got one run yesterday as the radiator got damaged. I do believe it will 60' better with more tuning.
ProSport, I have always raced A & B bodies. This thing is like a go cart compared to them. Feel like my azz is dragging the ground.
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696417
11/10/14 12:40 AM
11/10/14 12:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id like to know what CI your at too. With a 11.2 comp and a small block and big heads , the 60,s will be soft with the cam installed @ 106 ICL Depending on your CI, you might want to install that cam at about a 100 to 102 ICL.IMO
Do you have a pic of the car to share?
Re: Finally got one semi decent run on it. [Re: Sport440] #1696418
11/10/14 12:59 AM
11/10/14 12:59 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
It's a 416.
Re: Finally got one semi decent run on it. [Re: rt66jim] #1696419
11/10/14 01:09 AM
11/10/14 01:09 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It's a 416.
Also, Im in agreement with you. You just have one Single run so far. I would tune away on it first as it is, and get a lot more runs on it and see what you get. If tuning doesn't bring the 60 ft. around, then maybe consider changing the cam timing.
