Re: Finally got one semi decent run on it.
[Re: rt66jim]
#1696407
11/09/14 03:21 AM
11/09/14 03:21 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Those are about the numbers I've been running in the good air. Same 60' a bit quicker in the 1/8 and same 1/4 ET but only 133 MPH so your really making steam on the top end. At 138 I think you have quite a bit of ET improvement left.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#1696408
11/09/14 03:58 AM
11/09/14 03:58 AM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Fantastic MPH for that ET. Heck my 9.91 pass was only 131 mph but with my small 550 lift solid cam and 4:88 gears my engine (408) is running out of snuff for the last 300 plus feet.
[Re: pittsburghracer]
#1696412
11/09/14 07:19 PM
11/09/14 07:19 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
The motor: 11.2:1, W2's ported by RyanJ, Victor W2 w/PF950HP, Cam is a MP 590 [Email]265@050[/Email] w/1.6 MP roller rockers, 17/8" x 31/2" chassis headers The trans: 727 w/TA 8" converter if flashes 5400 rev man VB 83/4 rear w/4.30 spool MW caps and axles, 11.5x29.5W slicks (95"of rollout) Car weighs 2550 w/driver. This drive train has been in 3 different bodies now. 1: 69 Dart street car full interior. 3500lbs/driver 4.30 gear 9x29 slicks. Best ET & MPH 11.18@1192: 69 Dart caged race car. 3225lbs w/driver 4.56 gear 12x29 slicks. Best ET & MPH 10.50@1253: Current combo.
[Re: rt66jim]
#1696413
11/09/14 08:01 PM
11/09/14 08:01 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That 60' is WAY off. Was the cam degreed in as the numbers look almost like the cam is retarded. That's a lot bigger cam than mine especially when your do the 1.6 rocker calculation.
[Re: rt66jim]
#1696414
11/09/14 10:49 PM
11/09/14 10:49 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I'm thinking the reason for the big MPH. Is the A/D of the body. Car didn't spin the tires when it left. According to a friend observing the run. So where do I start looking for 60' ET.
Nice new bests. That car with its MPH is a strong 9.75 car
I agree that the 60 doesn't match the MPH. It should be around a 1.34/5 or so.
Also your picking up 30 MPH on the second half, that's excellent. The lost 670 could be in the carbs transition circuit or it could be a cam timing issue. Since you not spinning the tires Id start there.
[Re: rt66jim]
#1696419
11/10/14 01:09 AM
11/10/14 01:09 AM
Sport440
Canton, Ohio
It's a 416.
Also, Im in agreement with you. You just have one Single run so far. I would tune away on it first as it is, and get a lot more runs on it and see what you get. If tuning doesn't bring the 60 ft. around, then maybe consider changing the cam timing.
