genIII turbo help with camshaft
#1696355
11/08/14 09:40 PM
11/08/14 09:40 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
CAM HELP for those of you keeping score at home, i tore down my perfectly running n/a hemi.. 68 barracuda now i am going the turbo route parts are coming in and its time to decide on a cam i have 76mm t4 turbo a 2006 5.7 short block 2008 6.1 heads and intake 85mm throttle body 3k ish stall 373 gear 27 inch drag radial
Re: genIII turbo help with camshaft
[Re: mcat4321]
#1696356
11/08/14 09:49 PM
11/08/14 09:49 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
If you only have one 76mm turbo, I would go with a stock cam. You will choke any good breathing V8 with that.
[Re: TRENDZ]
#1696357
11/08/14 09:54 PM
11/08/14 09:54 PM
mcat4321
cincinnati ohio
explain "choke" and "only one"
[Re: mcat4321]
#1696358
11/08/14 11:59 PM
11/08/14 11:59 PM
TRENDZ
Milwaukee WI
Choke: to limit breathing. Only one: more than zero, less than two.
[Re: TRENDZ]
#1696359
11/09/14 12:02 AM
11/09/14 12:02 AM
mcat4321
cincinnati ohio
thanks for the help ass
[Re: mcat4321]
#1696360
11/09/14 12:04 AM
11/09/14 12:04 AM
TRENDZ
Milwaukee WI
....And that's all the help you will ever get from me.
[Re: mcat4321]
#1696361
11/09/14 02:39 AM
11/09/14 02:39 AM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
What cam do you have in it now? How much horsepower do you want to make? Are you running a stock short block? I ask because they say 8psi is all the stock pistons can handle. Ring gap is also critical. That's probably a bigger contributing factor than weak pistons. Of course tuning is critical. But I know you are aware of that.
Best thing to do would be to call a vendor like modern muscle, hhp, Arrington, inertia. Etc and get several suggestions from those guys. They spec cams all day and know their shtuff.
I have a magazine article where they took an 06 5.7 stock short block and opened up the ring gaps to like 0.030, ported the heads, added a 6.1 intake and crane cam and put 17.3 psi to make 1127 hp. That's probably a bit optimistic but a 76 mm should be good to over 1000 hp. 8psi should be good for like 600 650 with non ported heads. Ported heads would be worth some more.
