MSD distributor cap question #1696145
11/08/14 05:45 PM
11/08/14 05:45 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Is there a non hei cap available to use factory wires? Buddy has a ready to run msd distributor in his 440 and would like to factory female end wires at the cap.
Re: MSD distributor cap question [Re: SCATPK] #1696146
11/08/14 07:27 PM
11/08/14 07:27 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You can use a pre-HEI points style GM cap on the distributor also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: MSD distributor cap question [Re: 71yelladustr] #1696147
11/08/14 09:45 PM
11/08/14 09:45 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Have a part number as I am getting mixed messages that one is available?
Re: MSD distributor cap question [Re: SCATPK] #1696148
11/10/14 11:45 AM
11/10/14 11:45 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i would need to see a picture of his ready to run distributor to confirm # of a cap
Re: MSD distributor cap question [Re: Joesixpack] #1696149
11/10/14 04:39 PM
11/10/14 04:39 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The MSD cap is based off of the GM point distributor cap. A regular Point distributor cap from a GM point distributor will have the other spark plug ends on it.
...FAFO...
Re: MSD distributor cap question [Re: skicker] #1696150
11/10/14 09:25 PM
11/10/14 09:25 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Re: MSD distributor cap question [Re: skicker] #1696151
11/11/14 10:25 AM
11/11/14 10:25 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
...FAFO...
Re: MSD distributor cap question [Re: skicker] #1696152
11/11/14 10:34 AM
11/11/14 10:34 AM
maryland
74yellowduster Offline
maryland
everything is going to the spark plug type ends for the distributor caps... even the newer aftermarket coils are the same connectors. i'm using a set of taylor wires (i have the same dizzy just a low deck version on my 400)
http://www.taylorvertex.com/spark-plugs/thundervolt50-custom-wire-sets/
TAY-98087
