new to mopar
#1696055
11/08/14 01:09 PM
11/08/14 01:09 PM
Posts: 3 ok
big3fan
ok
new to mopar and moparts , recently purchased d250 , 360 tbi , smokey needs engine maybe just heads , found 2000 mpi engine , like to know if it can replace the tbi motor by using the long block and all my accessories , intake tbi unit , exhaust manifolds , transmission , basically are the block and heads the same , would appreciate any help , thanks in advance.
Re: new to mopar
[Re: big3fan]
#1696056
11/08/14 01:20 PM
11/08/14 01:20 PM
RapidRobert
Welcome aboard ![](/ubbthreads/images/graemlins/thumbs.gif) . I do not have exp in that area but others here do. Hang loose & you'll get some expert guidance
Re: new to mopar
[Re: buildanother]
#1696058
11/08/14 01:53 PM
11/08/14 01:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You'll have to redrill the intake bolt holes in the heads on the Magnum. The Magnum angle is pretty much vertical, where as the LA is more like 45 degrees.
The ends of the Magnum heads are a bit different than the LA's so you will have to mock up and rework the accessory brackets to fit. Doing this on the engine stand is the easiest way.
Magnums use a different external balance weight, you will have too address that as well.
The Magnum does not use air injection so you will have to seal those ports in the manifolds if you reuse the LA manifolds.
Re: new to mopar
[Re: big3fan]
#1696059
11/08/14 03:43 PM
11/08/14 03:43 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Welcome aboard!
I'd be tempted to drop the entire magnum in the truck and drop a carburetor on it. The necessary intake can be had for about $300. You can probably use your factory fuel pump with a regulator and a return line.
The tbi was a great running engine but was sadly lacking in performance. It'll get you around town forever but don't expect much enthusiasm.
The 5.9 Magnum has a lot more power and performance.
Re: new to mopar
[Re: big3fan]
#1696061
11/08/14 08:14 PM
11/08/14 08:14 PM
feets
Senior Management
Senior Management
Irving, TX
If you're going to rebuild try for a bit more compression. Other than that, there isn't much you can do to get more power without upsetting the tbi.
There's always the carburetor approach or aftermarket EFI. With either of those the sky is the limit.
Re: new to mopar
[Re: DaytonaTurbo]
#1696063
11/09/14 03:38 AM
11/09/14 03:38 AM
RapidRobert
An option would be a "crosswind" intake (carb flange/mag bolt pattern for several hundred $$$, a garden variety LA timing cover/fuel pump and hughes cam extension (for the eccentric to power the mech fuel pump) If going carbed. I think the LA water pump is required also. Not sure what dists yours would have but if needed a common LA 70's electronic dist would drop in
Re: new to mopar
[Re: feets]
#1696065
11/09/14 03:40 PM
11/09/14 03:40 PM
RapidRobert
Yes Feets plan would be even better (& easier). I did not know Eddy had a mag intake. I'd think it's quality would be better than the crosswind tho I hear they have taken care of alot of the casting issues the early production ones had
Re: new to mopar
[Re: DaytonaTurbo]
#1696068
11/09/14 08:24 PM
11/09/14 08:24 PM
Supercuda
About to go away
About to go away
up yours
Guess we ought to ask why he wants to keep the TBI, if it's for smog then the only aftermarket intake I know of with EGR provisions is the Performer and it's not any more Magnum compatible than the stock TBI intake and he may as well keep that by redrilling the heads.
Re: new to mopar
[Re: DaytonaTurbo]
#1696070
11/09/14 10:31 PM
11/09/14 10:31 PM
Supercuda
About to go away
About to go away
up yours
Having played with one of those TBI systems in it's stock form, I'd ditch it myself or convert to megasquirt controlled.
