new to mopar #1696055
11/08/14 01:09 PM
11/08/14 01:09 PM
ok
big3fan Offline OP
big3fan  Offline OP
ok
new to mopar and moparts , recently purchased d250 , 360 tbi , smokey needs engine maybe just heads , found 2000 mpi engine , like to know if it can replace the tbi motor by using the long block and all my accessories , intake tbi unit , exhaust manifolds , transmission , basically are the block and heads the same , would appreciate any help , thanks in advance.
Re: new to mopar [Re: big3fan] #1696056
11/08/14 01:20 PM
11/08/14 01:20 PM
Welcome aboard . I do not have exp in that area but others here do. Hang loose & you'll get some expert guidance
Re: new to mopar [Re: big3fan] #1696057
11/08/14 01:26 PM
11/08/14 01:26 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Don't know if there is a manifold that will adapt your throttle body to magnum cyl heads. I had a few of those tbi 318-360's over the years, and found them very reliable but not as powerful as the magnum series. Roller cams and roller chain-gear sets were on many of them too.
Re: new to mopar [Re: buildanother] #1696058
11/08/14 01:53 PM
11/08/14 01:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'll have to redrill the intake bolt holes in the heads on the Magnum. The Magnum angle is pretty much vertical, where as the LA is more like 45 degrees.
The ends of the Magnum heads are a bit different than the LA's so you will have to mock up and rework the accessory brackets to fit. Doing this on the engine stand is the easiest way.
Magnums use a different external balance weight, you will have too address that as well.
The Magnum does not use air injection so you will have to seal those ports in the manifolds if you reuse the LA manifolds.
Don't be the exception.
Re: new to mopar [Re: big3fan] #1696059
11/08/14 03:43 PM
11/08/14 03:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Welcome aboard!
I'd be tempted to drop the entire magnum in the truck and drop a carburetor on it. The necessary intake can be had for about $300. You can probably use your factory fuel pump with a regulator and a return line.
The tbi was a great running engine but was sadly lacking in performance. It'll get you around town forever but don't expect much enthusiasm.
The 5.9 Magnum has a lot more power and performance.
- Stu Harmon
Re: new to mopar [Re: feets] #1696060
11/08/14 08:00 PM
11/08/14 08:00 PM
ok
big3fan Offline OP
big3fan  Offline OP
ok
thanks guys for all the great info , looks like rebuilding the original tbi motor or a least the heads ,would be the most simplistic way for me to go .
Re: new to mopar [Re: big3fan] #1696061
11/08/14 08:14 PM
11/08/14 08:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you're going to rebuild try for a bit more compression. Other than that, there isn't much you can do to get more power without upsetting the tbi.
There's always the carburetor approach or aftermarket EFI. With either of those the sky is the limit.
- Stu Harmon
Re: new to mopar [Re: big3fan] #1696062
11/09/14 03:05 AM
11/09/14 03:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can do the swap however like said the intake manifold isn't a drag and drop as the angle of the intakr manifold bolt holes is different. The easiest way to do this would be for you to get an aftermarket intake manifold. They make carbed intake manifolds for the magnums. You could fairly easily mate the tbi to the carb intake.
Do not try to put the tbi on top of the magnum intake. Those are designed for dry flow only.
Re: new to mopar [Re: DaytonaTurbo] #1696063
11/09/14 03:38 AM
11/09/14 03:38 AM
An option would be a "crosswind" intake (carb flange/mag bolt pattern for several hundred $$$, a garden variety LA timing cover/fuel pump and hughes cam extension (for the eccentric to power the mech fuel pump) If going carbed. I think the LA water pump is required also. Not sure what dists yours would have but if needed a common LA 70's electronic dist would drop in
Re: new to mopar [Re: RapidRobert] #1696064
11/09/14 02:31 PM
11/09/14 02:31 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Here's the Edelbrock Performer RPM intake for a carb. It's $285 with free shipping.
Stuff a regular distributor in the engine.
Pop a fuel pressure regulator on it to bring it down from 15 psi to 7.
Drop a carb on the intake and hit the road.
Keep the front end of the Magnum with the accessories. They're good pieces.
- Stu Harmon
Re: new to mopar [Re: feets] #1696065
11/09/14 03:40 PM
11/09/14 03:40 PM
Yes Feets plan would be even better (& easier). I did not know Eddy had a mag intake. I'd think it's quality would be better than the crosswind tho I hear they have taken care of alot of the casting issues the early production ones had
Re: new to mopar [Re: feets] #1696066
11/09/14 06:13 PM
11/09/14 06:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The OP asked about keeping the TBI. If he goes carb he'll need to address the kickdown and throttle linkage setup. I no longer remember what the TBI setup used and if it's adaptable to a carb. But I'd bet it's closer to the 2bbl than 4bbl setup.
Re: new to mopar [Re: Supercuda] #1696067
11/09/14 06:52 PM
11/09/14 06:52 PM
Manitoba, Canada
Manitoba, Canada
If the op wants to keep the tbi, his best option would be to put the crosswind magnum carb intake on and put the tbi on top of that. Everything else would basically drop on.
Re: new to mopar [Re: DaytonaTurbo] #1696068
11/09/14 08:24 PM
11/09/14 08:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Guess we ought to ask why he wants to keep the TBI, if it's for smog then the only aftermarket intake I know of with EGR provisions is the Performer and it's not any more Magnum compatible than the stock TBI intake and he may as well keep that by redrilling the heads.
Re: new to mopar [Re: Supercuda] #1696069
11/09/14 09:31 PM
11/09/14 09:31 PM
Manitoba, Canada
Manitoba, Canada
Sounds like he likes how the engine runs, just his is smokey and tired. A used magnum engine would be in way better shape and offer some hp improvement even if the tbi is retained. If it wasmmine and an everyday driver and peak ho is not the goal, i would keep the tbi.
Re: new to mopar [Re: DaytonaTurbo] #1696070
11/09/14 10:31 PM
11/09/14 10:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Having played with one of those TBI systems in it's stock form, I'd ditch it myself or convert to megasquirt controlled.
