Clutch and Brake Pedal Uneven........Update 68 B Body #1695365
11/06/14 11:07 PM
11/06/14 11:07 PM
New York
R/T1968R/T Offline OP
New York
As I stated in my last post, changed from drum brakes to power disc. Everything is bolted up and the pedals have at least 3 inches height difference. No fluid in the master yet. Everything feels fine, but it looks low....even with the gas pedal. I know they should be different, but that much?
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: R/T1968R/T] #1695366
11/06/14 11:08 PM
11/06/14 11:08 PM
New York
New York
side view
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: R/T1968R/T] #1695367
11/06/14 11:55 PM
11/06/14 11:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Supposed to be that way, says so right in the service manual. So you can leave your heel on the floor, and not throw everybody through the windshield.
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: R/T1968R/T] #1695368
11/07/14 12:02 AM
11/07/14 12:02 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Power is always low, should come up a little when you have it all set up IMO but normal to be much lower with power.
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: GTX MATT] #1695369
11/07/14 05:00 AM
11/07/14 05:00 AM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
that definitely don't look right to me, id say the pushrod is too short. looks like its almost on the floor.
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: ditchdrift] #1695370
11/07/14 12:23 PM
11/07/14 12:23 PM
New York
New York
The rug is not all the way down, because the column is out. There are a few inches until I hit the pan.
Re: Clutch and Brake Pedal Uneven........Update 68 B Body [Re: ditchdrift] #1695371
11/07/14 01:35 PM
11/07/14 01:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Why doesn't it look right? If the pedal doesn't hit the floor when bottomed out, then it's right. It's in black, and white in the service manual.
