2004 Dakota 4x4 Ball Joints
#1695092
11/06/14 12:26 PM
11/06/14 12:26 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
Can the upper ball joints on a 2004 Dakota 4X4 be pressed out or do they need to be chiseled out? Or should I just change the whole control arm assembly?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 2004 Dakota 4x4 Ball Joints
[Re: buildanother]
#1695094
11/06/14 05:07 PM
11/06/14 05:07 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
No rivets on the lower ball joints in a 4wd. the quickest way to get them out is to use 2 hammers, a large ball peen with the rounded side resting on the top of the ball joint. With the LCA supported by a jackstand, smack the flat side of the ball peen hammer with another BFH. This will keep you from mushrooming the top of the old joint and protect the control arm. The new joint will need to be pressed back into the control arm.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#1695095
11/07/14 01:46 AM
11/07/14 01:46 AM
Posts: 4,945 WI
Dcuda69
WI
Wow...the question was about uppers,not lowers. "Smacking" 2 hammers together is also not the greatest idea(although I've done it myself)They are hardened steel and can shatter.
