Front tires cupping on my 06 2500CTD 2wd. #1694868
11/05/14 07:29 PM
11/05/14 07:29 PM
St Leonarc Md
stormer41 Offline OP
St Leonarc Md
Noticed my front tires are cupping. it is noticeable, when I am pulling my 32 ft. travel trailer. We are going to be traveling alot next year, and would like to have this little problem solved. Any advise offered would be helpful. Was thinking balance and checking the alignment for starters. Thoughts???
Proud owner of a 1991 Dodge Ramcharger LE 2wd.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: stormer41] #1694869
11/05/14 08:30 PM
11/05/14 08:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
cupping usually means a shock problem, if you are towing make sure you load is level
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Quicktree] #1694870
11/05/14 10:19 PM
11/05/14 10:19 PM
St Leonarc Md
St Leonarc Md
Using a weight distribution hitch from Reese. Question about shocks...... What brand to get??
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: stormer41] #1694871
11/05/14 10:53 PM
11/05/14 10:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I usually just buy a heavy duty shock for my tow vehicle. try napa or your local parts store and tell them your application.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: stormer41] #1694872
11/05/14 11:10 PM
11/05/14 11:10 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Lot's of reasons why it can happen, Pictures would help.
IMO, balance most often causes "cupping".
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: stormer41] #1694873
11/05/14 11:12 PM
11/05/14 11:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
Have your alinement checked with your trailer loaded and attached to your truck.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Challenger 1] #1694874
11/05/14 11:17 PM
11/05/14 11:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yep, thats another possible cause.
http://www.youtube.com/watch?v=XG2mmIcQRIA
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Quicktree] #1694875
11/05/14 11:48 PM
11/05/14 11:48 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Better check those lower ball joints.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: moparmarks] #1694876
11/07/14 12:37 AM
11/07/14 12:37 AM
They are known to feather outer edges--The Goodyears are the worst for that--other brands do it much less--massive constant rotation with x -ing is my answer works! usually every 3500 miles or so--change direction on the tires --it really helps
The Wranglers that came on mine were pure t junk
Michlin is the way to go
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Challenger 1] #1694877
11/07/14 01:13 AM
11/07/14 01:13 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
That's the idea..however that would be impossible on most drive-on style lifts. I would try to duplicate loaded tongue weight in the bed as close as possible. My bet is a combination of alignment(usually f'd up from the factory) and some good shocks will take care of it. Alignment angles change a LOT when you hang trailers on trucks......be sure to find an alignment tech.....not just some guy running an alignment machine....then be SURE to explain what the vehicle is used for.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Dcuda69] #1694878
11/07/14 01:19 PM
11/07/14 01:19 PM
Cincinnati, Ohio
Cincinnati, Ohio
Might not be possible to have the trailer attached?...I'd go to a semi truck alinement shop, not where you take your honda.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Challenger 1] #1694879
11/07/14 08:38 PM
11/07/14 08:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
That would work too if they have the right heads(targets). I just sat in on a small Hunter heavy duty alignment seminar. They said the equipment would work on SOME light duty trucks depending on wheel size and vehicle height.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: Challenger 1] #1694880
11/07/14 09:11 PM
11/07/14 09:11 PM
Is that where you take your truck is to a semi shop? Most semi racks are to big for a p/u.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: ] #1694881
11/07/14 09:17 PM
11/07/14 09:17 PM
And see that last set of Wranglers that I had on my 1-ton went for 80,000 miles and my truck is always loaded up. I've also have great luck with Michlins too but the last set I have on it cupped out really bad when my LBJ's went out. Pissed me of cause they were fairly new.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: stormer41] #1694882
11/07/14 09:52 PM
11/07/14 09:52 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Depending on the tire, all can seem right but it just comes down to rotating tires to keep them round. It seems to be something that is rarely thought of these days, but can be pretty vital on some applications.
Jeep guys rotate their mud terrains every 5-7,000 miles [or should], even when properly balanced and aligned.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: GoodysGotaCuda] #1694883
11/08/14 12:44 AM
11/08/14 12:44 AM
Central NC
gch Offline
gch  Offline
Central NC
Low air pressure can cause cupping as well.Rotate on a 5k mile schedule and watch the air pressure as well.A good alignment never hurts and they can check the front end at that time as well.
Re: Front tires cupping on my 06 2500CTD 2wd. [Re: GoodysGotaCuda] #1694884
11/09/14 12:47 PM
11/09/14 12:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
This is true and good advice.
Years ago I bought 4 new BF AT 33" tires for this 87 ramcharger. They came with a life time rotate & balance or something like that.
I took them off at my shop to rotate the tires on a regular basis. When I did, I ran the wheels and tires down the street a 1/4 mile to the shop where I bought them and have them re check the balance. After like the 3rd time I started to doubt that they were actually checking them, so I took the weights before taking them in. Then they came back with new weights. The manager started checking serial numbers on the tires. Then I drove the truck down there and showed them my truck and tires one day. Then we were good for years.
I put the lift, gears and tires on the truck when it was brand new in 87 and drove it for 7 years and 90K+ miles before it was sold it.
Here's crappy picture of a picture, it's one of 2 pictures I have of the truck. It was ordered as a 360 truck new stripped and I did the lift, tires and 4:11 gears front and back when it was new in 87. I towed a 20' boat with it for years. It was a company vehicle, not really mine.
Moparmarks, Yes that's where I send our F-350/450 to a semi shop. What rack they put it on? I don't know. This is one of those shops that work on ford F-53 motorhome chassis and know how to straighten out those deals once the motorhome is mounted on the chassis which changes the alinement a lot. So I feel they have more experience with alinements with heavy loads verses the neighborhood shop.
