Dana the same for E and 71 B body? #1694840
11/05/14 06:41 PM
11/05/14 06:41 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
Will a Dana from a 71 Charger fit in a 70 Challenger with no modification's?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Dana the same for E and 71 B body? [Re: DaveDudek] #1694841
11/05/14 06:44 PM
11/05/14 06:44 PM
New York
Mopucky Offline
Mopucky  Offline
New York
E body perch to perch is 46"
71 B body is 47.3"
Re: Dana the same for E and 71 B body? [Re: Mopucky] #1694842
11/05/14 06:52 PM
11/05/14 06:52 PM
N of Detroit
N of Detroit
Thanks! Sounds like it's doable.
Dave Dudek
Re: Dana the same for E and 71 B body? [Re: DaveDudek] #1694843
11/05/14 07:39 PM
11/05/14 07:39 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Dave:
Here's some info I have saved on my computer concerning dana dimensions:
'71-'72 B-body 57 7/8" housing, 63" axle flange to flange, 47.3" perch, 35 spline track-lock sure-grip, 7290 yoke
'70 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline power-lock sure-grip, 7290 yoke
Can't say if it is 100% accurate, but if it is your differential will be an inch and 3/8 wider than stock.
Jess
Yeah, it's hopped up to over 160...
Re: Dana the same for E and 71 B body? [Re: jt4406] #1694844
11/05/14 07:44 PM
11/05/14 07:44 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
You want to put a early B body rear in it and that way when you put the boots on you have more room. Buy the hangers and they bolt right in
Re: Dana the same for E and 71 B body? [Re: scatpacktom] #1694845
11/05/14 08:03 PM
11/05/14 08:03 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Along those lines......
'66 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 U-bolt yoke
'67 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 strap yoke
'68-'69 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 23 spline power-lock sure-grip, 7290 yoke
'70 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 35 spline power-lock sure-grip, 7290 yoke
By the way, I think I got these dimensions from Dr. Diff's website.
Jess
Re: Dana the same for E and 71 B body? [Re: jt4406] #1694846
11/05/14 08:19 PM
11/05/14 08:19 PM
N of Detroit
N of Detroit
Okay, so a 70 E-body and a 71 B-body is not a quicky swap. thanks!
Dave Dudek
Re: Dana the same for E and 71 B body? [Re: DaveDudek] #1694847
11/05/14 08:28 PM
11/05/14 08:28 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
71 B-body Dana's are quite hard to find and worth more to the right buyer, so don't cut it!
Admiration For Multiple Carburetor Vehicles...
Re: Dana the same for E and 71 B body? [Re: DaveDudek] #1694848
11/18/14 06:03 PM
11/18/14 06:03 PM
Oklahoma
smokkem Offline
smokkem  Offline
Oklahoma
I put a 1970 B body Dana in my 71 Cuda, the B body Dana is basically 1" narrower on each side than an E body Dana. Take all your measurements, including degrees and locations of the spring perches, carefully cut/grind of the perch welds and relocate the perches on the axle housing to match the E body location. I used Hemi springs and put on a stock sway bar set up, works and looks perfect. Check with Dr Diff-- www.doctordiff.com for other options using special brackets.
