Dana the same for E and 71 B body?
#1694840
11/05/14 06:41 PM
11/05/14 06:41 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Will a Dana from a 71 Charger fit in a 70 Challenger with no modification's?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: Dana the same for E and 71 B body?
[Re: Mopucky]
#1694842
11/05/14 06:52 PM
11/05/14 06:52 PM
DaveDudek
N of Detroit
Thanks! Sounds like it's doable.
[Re: DaveDudek]
#1694843
11/05/14 07:39 PM
11/05/14 07:39 PM
Posts: 1,567 Ky
jt4406
Ky
Dave: Here's some info I have saved on my computer concerning dana dimensions: '71-'72 B-body 57 7/8" housing, 63" axle flange to flange, 47.3" perch, 35 spline track-lock sure-grip, 7290 yoke '70 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline power-lock sure-grip, 7290 yoke Can't say if it is 100% accurate, but if it is your differential will be an inch and 3/8 wider than stock. Jess
Yeah, it's hopped up to over 160...
[Re: scatpacktom]
#1694845
11/05/14 08:03 PM
11/05/14 08:03 PM
Posts: 1,567 Ky
jt4406
Ky
You want to put a early B body rear in it
Along those lines......
'66 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 U-bolt yoke
'67 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 strap yoke
'68-'69 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 23 spline power-lock sure-grip, 7290 yoke
'70 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 35 spline power-lock sure-grip, 7290 yoke
By the way, I think I got these dimensions from Dr. Diff's website.
Jess
[Re: jt4406]
#1694846
11/05/14 08:19 PM
11/05/14 08:19 PM
DaveDudek
N of Detroit
Okay, so a 70 E-body and a 71 B-body is not a quicky swap. thanks!
