Re: Need a rotisserie....have questions.
[Re: Challenger 1]
#1694462
11/19/14 10:07 PM
11/19/14 10:07 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Cool deal! and you got a dog house out of the deal too.
No comfy couch to lounge on while watching over the front yard, NO KOLBI. heck really it is his house, we just live in it! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: carcrazyguy]
#1694464
11/23/14 11:17 AM
11/23/14 11:17 AM
Challenger 1
Cincinnati, Ohio
Okay now that I have the rotissire......I feel really dumb! I probably have more questions now than I had before I bought one! I have seen a lot of cars mounted up, I have had the Duster mounted up on one.....and still have no idea if we are doing it right! ![](/ubbthreads/images/graemlins/image_294343.gif)
First I am not mechanically gifted as many here are. We have measured, re measured, and re measured.....checked, re checked, and re checked again. Just can't get the concept of how to balance before we spin it over. We have made sure the front and rear crossbars are the same distance from the floor. The car is still top heavy. We looked at the instructions for using the balance that came with the kit. Still have yet to figure out how that is going to work......??? Yep I feel really dumb now!
IMO I wouldn't mount it there. I would use the rear sprang hanger hole. Lot's stronger there. Need more pictures, can see what what your doing yet.
[Re: carcrazyguy]
#1694469
11/23/14 02:40 PM
11/23/14 02:40 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Your fine mounted in the manner you show, did mine to the same locations without issue, though my mounting was a bit different in the structure.
The real choice you face is limitation of mounting position;
As shown, you'll need to touch up paint if you leave it on the jig, but it's horribly convenient when mounting your pre-assembled rear axle/spring combo and checking fitment of the rear valance.
Mounting to the spring perch makes for better paint access but makes for a pain while trying to remove and reinstall rear axle/spring combo. This location also eliminates you from checking the fitment of the rear valance unless you intend to temporarily take it off the jig.
As for balancing, use the whirly jig instructions, the base concept is that as the car is raised relative to the rotation center point, a balance position will be realized. This location may change if you mount the car with anything on it (perhaps glass still in doors, front suspension components, ect, ect)
Working on the jig is a real saver, the benefits far out weigh the inconvenience of time to mount the car.
Whirly Jig recommends using round bar stock running the length of the system in each of the lower outboard positions, for several reasons I chose instead to use square tube steel sections with an oversized coupling in the center to join the lengths, this now gives me better flexibility to have correct length tubing runs based on the cars actual length with minimal excess tubing protruding from beyond the jig. This approach also makes it easier to transport should you decide to move the jig less a car.
What I do is rent mine for minimal money, gets free storage and helps pay for itself. If I need it in the future it's available for reclaim, though I admit I rent only to trustworthy friends.
Good luck whatever you decide for mounting position and setup.
[Re: AAR#2]
#1694470
11/23/14 04:29 PM
11/23/14 04:29 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Okay. This morning we rewatched the video. We did as mentioned above and raised the yoke. That got us balanced!! Now we are trying to decide how to brace the back to the frame rail or leaf spring hanger. If we use a leaf spring hanger the rubber bushing will flex. So.....
[Re: carcrazyguy]
#1694471
11/23/14 04:38 PM
11/23/14 04:38 PM
Posts: 9,404 Texas
carcrazyguy
Texas
So anyone have good close up pics of ebody mounting? We were thinking of attaching an angle iron plate to the frame rail and the rear brace.
[Re: Stanton]
#1694478
11/23/14 08:36 PM
11/23/14 08:36 PM
Posts: 9,404 Texas
carcrazyguy
Texas
What type of bushing or fitting do you use in the eyelet the frame rail? I think I will order US Car Tool subframe connectors tomorrow. Then tack them in place (multiple places), while the car is on jack stands. That way I should not have to worry about the body flexing when we roll it over on its side or top for the first time. ![](/ubbthreads/images/graemlins/nervous.gif)
