Lock Cylinder Lube: What Do You Use? #1693646
11/02/14 08:53 PM
11/02/14 08:53 PM
New Jersey
P
Powerflow Offline OP
P
New Jersey
With winter coming, I like to lube the lock cylinders in all my cars so they don't freeze. I've mostly used WD-40, but I've heard others use straight silicone spray, liquid graphite, etc. What works for you?
Re: Lock Cylinder Lube: What Do You Use? [Re: Powerflow] #1693647
11/02/14 09:23 PM
11/02/14 09:23 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
http://www.agscompany.com/lubricants/automotive/179
I don't use stuff like oil,WD-40, etc. cuz it can become sticky over time. This stuff works for me on padlocks, car door locks, car trunk locks, etc. I use it on door hinges followed by some dripless oil....
Re: Lock Cylinder Lube: What Do You Use? [Re: Powerflow] #1693648
11/03/14 12:34 AM
11/03/14 12:34 AM
What ever type your parts house has on hand, graphite based liquid, Squirt it in & the liquid evaporates leaving the graphite to lube the lock
Re: Lock Cylinder Lube: What Do You Use? [Re: RapidRobert] #1693649
11/03/14 01:13 AM
11/03/14 01:13 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I do facility maintenance on 8 school buildings (lots of doors!)
I use Houdini lock lube - we get it at our local locksmith but I know Amazon has it
Re: Lock Cylinder Lube: What Do You Use? [Re: Powerflow] #1693650
11/03/14 09:50 PM
11/03/14 09:50 PM
Mt.Washington,KY
71ChargerSE Offline
71ChargerSE  Offline
Mt.Washington,KY
I work in the lockshop of a large school district-160 buildings. We use Triflow on everything pin tumbler and wafer,works great.They make it in aerosol and little bottles of oil with built in thin little tube. Really works and you can get it about anywhere.
Re: Lock Cylinder Lube: What Do You Use? [Re: 71ChargerSE] #1693651
11/03/14 09:55 PM
11/03/14 09:55 PM
IN
ahy Offline
ahy  Offline
IN
Just for fun, I'll add I use WD40 even though it is not supposed to be the best. I always have it around and it seems to work OK.
Re: Lock Cylinder Lube: What Do You Use? [Re: Powerflow] #1693652
11/03/14 10:22 PM
11/03/14 10:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've used WD40 for ever on 20+ vehicles and 4 buildings. Hasn't caused any problems and keeps them from freezing up during the winter.
I'm sure there's better, but I have found the need for it.
