Page 1 of 3 1 2 3
66 valiant Wagon 440 W2 - Best handling OEM based parts #1692573
10/30/14 06:26 PM
10/30/14 06:26 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I basically want a sub 3000 pound 66 wagon with the best overall handling and braking using (primarily )OEM-sourced parts and assuming 15" Max wheels (15 x 8 cop wheels most likely). Only exception may be the rear brake discs which I'll probably do a Dr diff kit.
Probably 11.75" Cordoba rotors, 340 A body .870 torsion bars (or slightly larger since I've got some fatter tires), XHD (340) springs in back with bolt on swaybars.
This is not gonna be a drag car, I want this one to drive and drive often. 5500 max RPM, 10:1 and "only" about 525 hp with crushing torque curve all through the powerband. 3.23 or 3.55 gears, shift kit. Motor is already sorted and ready to go.
So basically I want a slightly improved police type ride in a ~1000 pound lighter and better weight distributed package.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692574
10/30/14 06:55 PM
10/30/14 06:55 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
They made W2 heads for a 440 big block? Never heard of that.
Or would that be some sort of model number for the station wagon?
ONLY an .87 t-bar???? I'd go with a 1" at least and probably a 1 1/4 with a 440 big block, depending if that is really the engine size. Or a 1" min. with a 340ish small block.
If you REALLY want an .870 t-bar, then get a much heavier anti-sway bar, that way the .870 t-bar will allow for a softer/better/smoother ride, and the heavier front anti-sway bar and matched rear bar will allow for more spirited driving of the curvies, been there, done it that way.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: amxautox] #1692575
10/30/14 06:58 PM
10/30/14 06:58 PM
Weddington, N.C.
Weddington, N.C.
440 stroker smallblock W2
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692576
10/30/14 07:17 PM
10/30/14 07:17 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I can advise also to use 1" bars.
I went from the stock 0.87" bars to 1" JustSuspension bars in my daily '73 Dart which weighs about 3175 lbs and I'm sure I wouldn't be scared of installing 1.06" or 1.10" bars in it.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692577
10/30/14 07:32 PM
10/30/14 07:32 PM
amxautox Offline
amxautox  Offline
Kool.
Tom
author unknown
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: amxautox] #1692578
10/30/14 07:58 PM
10/30/14 07:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you are going to have a thousand pound lighter (than what?) package you need to remember one thing. Spring rates need to match corner weights.
Just because someone ran a 1" bar in a stockish weighing A body does not mean it's a good choice for one that weighs a thousand pounds less.
Not to mention that wagons have a different, usually better, weight distribution than non-wagons, that will also affect spring rates. Get everything but the suspension sorted out, then get corner weights for us so we can sort out options based on good data, not monkey see, monkey do, suggestions.
Don't be the exception.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Supercuda] #1692579
10/30/14 08:39 PM
10/30/14 08:39 PM
Weddington, N.C.
Weddington, N.C.
Thanks,
Yeah the wagon will be a bit lighter and bit better balanced front to rear than a 340 Duster, balance is the key, i dont really want the ride to be super stiff like my old 94 Firehawk. I now have a 99 V6!Camaro (that my Dad left me) and to be honest it's better balanced and more fun to corner and live with every day than the hawk was.
The car is over at Stephen Daurity's shop and we're just now going over everything.
Thanks!
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692580
10/30/14 11:29 PM
10/30/14 11:29 PM
IN
ahy Offline
ahy  Offline
IN
Tight and fun... as a first step, suggest you beef up/tighten up the unibody. Frame connectors, 2"x 2" box section or more, and full welded/gusseted K frame as a start. Torque boxes and boxed LCA's would help also. The car will feel tighter and be able to handle stiffer springs/shocks better... not much point in stiffer springs if the unibody flexes instead. My original 318/auto Challenger drove better with these changes alone. With a BB and 5 speed + stiffer springs/shocks it really drove better.
Big front sway bar definitely. Rear, maybe. Suggest you drive it first and decide on the rear bar.
As far as spring rates, agree knowing the weight would really help. XHD springs sound about right... though I don't know what's out there in A body length springs. As far as T bars... the trend is to go with really big bars. With your goals I'm not sure "really big" is needed though. Significantly more than stock, no doubt. 1" may be more than you need/want with a lighter package and your goals. Maybe 1 step down would be better. Its also a matter of budget... 1" in an A body length really needs high end shocks. .94" HD/Police bars not so much.
Good luck!
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: ahy] #1692581
10/31/14 03:41 PM
10/31/14 03:41 PM
Weddington, N.C.
Weddington, N.C.
Frame connectors are the first order of business, Got the car over at Daurity's and it don't get no better than that for fab work
Reconsidering maybe a .94-1.0 bar due to the fact I will have a bigger footprint than a 340 duster's little E70-14's. XHD's in the back with some bolt on swaybars should firm it up.
Can somebody give me a bit more insight into the boxed lower control arms? Seems like it would be easy to bridge the LCA channels and stiffen them up a bunch without adding much extra weight.
The car is going to be a really cool driver with lots of party room in the back
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692582
10/31/14 03:44 PM
10/31/14 03:44 PM
Weddington, N.C.
Weddington, N.C.
W2 heads, mild 251/259 @ .050 roller, peak torque will be around 4000 probably shift it at 5400. Just want a big block mid range, should have that in spades.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692583
10/31/14 04:10 PM
10/31/14 04:10 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Give Dick at Firm Feel a call. he has some experience with the handling characteristics of early A bodies.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: dart4forte] #1692584
10/31/14 08:14 PM
10/31/14 08:14 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
Tire kicker
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: kotacars] #1692585
10/31/14 09:14 PM
10/31/14 09:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Tire kicker
What?
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: dart4forte] #1692586
10/31/14 10:48 PM
10/31/14 10:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Depending on your budget, IMO shocks are a great investment. I have the Hotchkis 1.5's on my Dart and they are a super shock. Your wagon may benefit from a B-body part # in the rear maybe? Even if you go conservative on spring rate, a shock valved with some balls will give the car a sporty,controlled and "in command" feel.
Mopar to the bone!!!
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: kotacars] #1692587
10/31/14 10:55 PM
10/31/14 10:55 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Tire kicker
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692588
10/31/14 11:24 PM
10/31/14 11:24 PM
AndyF Offline
AndyF  Offline
Firm Feel and DoctorDiff have everything that you need.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: AndyF] #1692589
10/31/14 11:42 PM
10/31/14 11:42 PM
IN
ahy Offline
ahy  Offline
IN
Reinforced LCA's. A simple plate welded to the bottom of the LCA. Helps handle sway bar loads. FF and (from memory) Mancini handles the plates. FF can do the welding also if desired.
http://www.firmfeel.com/a_body_mopar_lower_control_arm_reinforcement.html
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: AndyF] #1692590
10/31/14 11:46 PM
10/31/14 11:46 PM
Weddington, N.C.
Weddington, N.C.
Early A's seem to have a few challenges compared to the 67 laters, I never had one before but i like the light feel of it, even with the six it felt noticably lighter on its feet than the typical mopar.
I know Bob Tulius and others had some success in SCCA racing in the mid 60's with early A bodys, it should be fun for sure.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692591
11/01/14 12:27 AM
11/01/14 12:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would put 15x7 rallyes on it, would be a appropriate update.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: 72Swinger] #1692592
11/01/14 12:34 AM
11/01/14 12:34 AM
Weddington, N.C.
Weddington, N.C.
Planning on body color cop wheels with dog dishes
WIZE
In Car:
Page 1 of 3 1 2 3
