Steel Crank??? #169248
12/17/08 01:15 PM
12/17/08 01:15 PM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
I'm going to look at a couple of 440 cranks later this week. Without the obvious hammer and ring tone check, How do I tell the diff between steel and cast? The dampers have been removed.
Re: Steel Crank??? [Re: Mopar1] #169249
12/17/08 01:23 PM
12/17/08 01:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The casting line on the wrist pin throws will tell
you, if it has a wide line where it looks ground on
its a forged unit.... a thin line is a cast unit
wrist pin throws(first one and last one)
Re: Steel Crank??? [Re: MR_P_BODY] #169250
12/17/08 01:53 PM
12/17/08 01:53 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Some of the cast 440 cranks have the casting clock on them. They have sharper edges also.
Re: Steel Crank??? [Re: Mopar1] #169251
12/17/08 04:14 PM
12/17/08 04:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The tech archives have a good photo showing the difference between cast/forged.
http://www.moparts.org/Tech/Archive/motor/8.html
Ringing is not always a good test for forged/cast, if you hold a cast crank off the floor it will ring when struck.
Re: Steel Crank??? [Re: John_Kunkel] #169252
12/17/08 04:22 PM
12/17/08 04:22 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Castings will also usually have raised numbers time/date etc info. Forgings with have any info stamped in.
Re: Steel Crank??? [Re: Scott Carl] #169253
12/17/08 06:23 PM
12/17/08 06:23 PM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
Thanks for the info guys!
Rick
Re: Steel Crank??? [Re: MR_P_BODY] #169254
12/17/08 06:53 PM
12/17/08 06:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
times have changed, I remember when the wrist pin was on the piston end of the conecting rod.
Re: Steel Crank??? [Re: bboogieart] #169255
12/18/08 12:22 PM
12/18/08 12:22 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
While I'm sure Mr. P-Body knows what he's talking about, I was thrown by that as well.... never heard of wrist-pins on a crank (???) "Wrist pin" is a term that is synomymos with "piston pin", isn't it?
Either way, I always have seen cast cranks as having very sharp, square edges, while forged cranks have more rounded edges.
Re: Steel Crank??? [Re: StealthWedge67] #169256
12/18/08 02:01 PM
12/18/08 02:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry about that... my error
