Re: Steel Crank???
[Re: Mopar1]
#169249
12/17/08 01:23 PM
12/17/08 01:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The casting line on the wrist pin throws will tell you, if it has a wide line where it looks ground on its a forged unit.... a thin line is a cast unit wrist pin throws(first one and last one)
Re: Steel Crank???
[Re: MR_P_BODY]
#169254
12/17/08 06:53 PM
12/17/08 06:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
times have changed, I remember when the wrist pin was on the piston end of the conecting rod.
Re: Steel Crank???
[Re: bboogieart]
#169255
12/18/08 12:22 PM
12/18/08 12:22 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
While I'm sure Mr. P-Body knows what he's talking about, I was thrown by that as well.... never heard of wrist-pins on a crank (???) "Wrist pin" is a term that is synomymos with "piston pin", isn't it?
Either way, I always have seen cast cranks as having very sharp, square edges, while forged cranks have more rounded edges.
Re: Steel Crank???
[Re: StealthWedge67]
#169256
12/18/08 02:01 PM
12/18/08 02:01 PM
MR_P_BODY
Sorry about that... my error
