tire size conversion? #1692479
10/30/14 12:16 PM
10/30/14 12:16 PM
scratchnfotraction Offline OP
what does a 29x9.50x15 convert to in a metic tire?
235/75/15? 255? 265?
trying to figure speedo pinion tooth count.
i have a 235/75/15 with a 3.55 33 tooth
going to pop on some 29x9.50x15 mud tire. need to correct speedo
Re: tire size conversion? [Re: scratchnfotraction] #1692480
10/30/14 12:37 PM
10/30/14 12:37 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Re: tire size conversion? [Re: Fab64] #1692481
10/30/14 12:39 PM
10/30/14 12:39 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: tire size conversion? [Re: herkamer] #1692482
10/30/14 07:19 PM
10/30/14 07:19 PM
BDW Offline
BDW  Offline
255/70/15, 29.1" tall, as stated 32 should do it.
Re: tire size conversion? [Re: BDW] #1692483
10/31/14 06:40 PM
10/31/14 06:40 PM
thanks guys.
I have the 32 pinion yea!
Re: tire size conversion? [Re: scratchnfotraction] #1692484
11/02/14 03:32 AM
11/02/14 03:32 AM
I would put a piece of flat stock across the top of a rear tire & measure the distance from the bottom side of it down to the ground for an exact diameter measurement. Better yet is out in a parking lot to get a rear valve stem at 6 0'clock & hook your tape inbetween 2 bricks at that point then roll the car forward in a straight line till the valve stem is back at 6 0'clock then pull the tape forward & measure that distance then divide Pi (3.1416) into that number for rollout (which is what the speedo/odo will see) as tires ain't exactly round (loaded). Be sure to jack up the car as high as you can on the dr side to minimize fluid loss for the pinion change
Re: tire size conversion? [Re: RapidRobert] #1692485
11/02/14 06:54 PM
11/02/14 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Better yet, paint a dot of enamel on the center of the tread and roll the car until two paint dots appear on the ramp...measure between them for the most accurate roll out then divide by pi to get the working diameter.
Re: tire size conversion? [Re: Fab64] #1692486
11/02/14 08:50 PM
11/02/14 08:50 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
http://tire-size-conversion.com/metric-tire-conversion/
Hmm. That tells me my 26x12x15 are only 215/65x15. In reality, they are closer to 305/45x15. I wonder what they are using as their point of calculation?
Re: tire size conversion? [Re: TC@HP2] #1692487
11/02/14 08:54 PM
11/02/14 08:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Don't trust conversion charts, measure your tire for more precise speedo calculations.
