tire size conversion?
#1692479
10/30/14 12:16 PM
10/30/14 12:16 PM
Posts: 15,487 Florida
scratchnfotraction
what does a 29x9.50x15 convert to in a metic tire? 235/75/15? 255? 265? trying to figure speedo pinion tooth count. i have a 235/75/15 with a 3.55 33 tooth going to pop on some 29x9.50x15 mud tire. need to correct speedo
Re: tire size conversion?
[Re: scratchnfotraction]
#1692484
11/02/14 03:32 AM
11/02/14 03:32 AM
RapidRobert
I would put a piece of flat stock across the top of a rear tire & measure the distance from the bottom side of it down to the ground for an exact diameter measurement. Better yet is out in a parking lot to get a rear valve stem at 6 0'clock & hook your tape inbetween 2 bricks at that point then roll the car forward in a straight line till the valve stem is back at 6 0'clock then pull the tape forward & measure that distance then divide Pi (3.1416) into that number for rollout (which is what the speedo/odo will see) as tires ain't exactly round (loaded). Be sure to jack up the car as high as you can on the dr side to minimize fluid loss for the pinion change
[Re: TC@HP2]
#1692487
11/02/14 08:54 PM
11/02/14 08:54 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Don't trust conversion charts, measure your tire for more precise speedo calculations.
