E Body/B Body K Frames
#1691599
10/28/14 01:01 PM
10/28/14 01:01 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I can't remember if the 70 b & e body k-frames interchange. I know that the part numbers are different but that doesn't always mean they are different or interchange. Picked one up, 70 e-body, at the Fall Fling to have on reserve for down the road repairs. I know 71- is different because of the steering box mount angle. Would like one on hand to replace my 70 b-body when needed. Thoughts anyone?
Carl Kessel
Re: E Body/B Body K Frames
[Re: Cab_Burge]
#1691601
10/28/14 02:20 PM
10/28/14 02:20 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Like Cab Barge posted it can be done but I think the steering gear box geometry is a couple of degrees different on the angles from an B Body to an E Body but it still works.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: CKessel]
#1691602
10/28/14 02:28 PM
10/28/14 02:28 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Like was said there's a slight steering box angle difference. 70-74 E-body is the same as 71-72 B-body.
70 B-body is truly a one year only K-member. It's got the 66-70 B-body steering box angle and the 70-72 short through the K-member sway bar cutouts. Those two features only intersect in on year: 1970 B-body.
