518 sensor plug? #1690767
10/26/14 01:05 PM
10/26/14 01:05 PM
BDW Offline OP
BDW  Offline OP
My 518 has a cut out at the top of the bell housing. Since I'm not using this, is there plug or recommended way to fill the spot?
Or should I just cover it up with duct tape and forget about it?
Re: 518 sensor plug? [Re: BDW] #1690768
10/26/14 02:25 PM
10/26/14 02:25 PM
yellow70charger Offline
If is crank position hole bothers you put. a piece a of ducktape on the inside and mounting face fill with jb weld when it hardens remove tape and sand down the top to fit the profile of the bell.
