coil over front on a duster? #169055
12/17/08 12:00 AM
12/17/08 12:00 AM
duster408 Offline OP
Has anyone ever put a coil over front on a duster? Does there have to be any mods to the lower control arm once the torsion bar is removed? Any other helpful suggestions. Thanks
Post deleted by Defbob [Re: duster408] #169056
12/17/08 12:22 AM
12/17/08 12:22 AM
Re: coil over front on a duster? #169057
12/17/08 01:52 AM
12/17/08 01:52 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
you can retain the stock LCA with the right mods.
also think about shock tower bracing as DusterDave said, a must do !
i make a complete coil over conversion kit also to think about
my website has details on the setup.
Bondo
Re: coil over front on a duster? [Re: BobsProFab] #169058
12/19/08 11:45 AM
12/19/08 11:45 AM
what mods are needed on the LCA's? Do you have pics?
Re: coil over front on a duster? *DELETED* [Re: duster408] #169059
12/19/08 01:17 PM
12/19/08 01:17 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
Post deleted by QWK_ENUF_511
WAXER
Re: coil over front on a duster? [Re: QWK_ENUF] #169060
12/19/08 06:48 PM
12/19/08 06:48 PM
I need some pics of stock LCA mods.
Re: coil over front on a duster? [Re: duster408] #169061
12/19/08 08:49 PM
12/19/08 08:49 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
1. you will need to en large the shock bolt hole on the LCA, its only 7/16
needs to be 1/2 for the coil over bearing end and make a few 1/8 spacers to take up the extra room.
2. press out your LCA pivot shafts and machine a 3/8 x 24 thread into the back of them, that way you can retain the LCA from not wanting to pull loose from the pivot shaft, only the bushing is holding it on.locite it on with a washer to retain it.
3. brace the shock towers, it will want to twist the top of the frame rails in towards the motor and break the spot welds in the front frame rail in time.
heres a pic of a new set of stock lower pivot shafts with a 3/8 x 24 thread in the back of them and a set of upper billet mounts heading Deigo Teds way i need the machine the spacers up for him yet
Bondo
Re: coil over front on a duster? [Re: BobsProFab] #169062
12/19/08 08:50 PM
12/19/08 08:50 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
closer shot
Re: coil over front on a duster? [Re: BobsProFab] #169063
12/21/08 12:42 PM
12/21/08 12:42 PM
thanks, I also saw somewhere welding done on the LCA,s is this necessary?
Re: coil over front on a duster? [Re: duster408] #169064
12/21/08 12:49 PM
12/21/08 12:49 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Search Alterktion on the web. I have one of there kits and it fit great and works great.
Post deleted by Defbob [Re: duster408] #169065
12/21/08 02:26 PM
12/21/08 02:26 PM
Re: coil over front on a duster? #169066
12/21/08 02:47 PM
12/21/08 02:47 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Right here. Coil Over Conversion
Not to hi-jack, but do you guys think this is enough reinforcement for the uppers?
I don't know if I'm going to end up with the coil over deal or not, but before the car gets painted I want to make sure what I have would work...
Re: coil over front on a duster? [Re: dizuster] #169067
12/21/08 02:48 PM
12/21/08 02:48 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
one more
Re: coil over front on a duster? [Re: dizuster] #169068
12/28/08 12:23 PM
12/28/08 12:23 PM
what length shocks do I need, and what should the ride height be?
Post deleted by Defbob [Re: duster408] #169069
12/28/08 12:34 PM
12/28/08 12:34 PM
Re: coil over front on a duster? #169070
12/28/08 12:53 PM
12/28/08 12:53 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
the best shock is the AFco M2/BNC
direct fit drag shock that is coil over ready with 5 inch of travel.
AFco is doing a awesome job at the mopar valving on these shocks which i have custom built and valved.
a few pics of a M2
Bondo
Re: coil over front on a duster? [Re: BobsProFab] #169071
12/28/08 12:53 PM
12/28/08 12:53 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
Re: coil over front on a duster? [Re: BobsProFab] #169072
12/28/08 12:56 PM
12/28/08 12:56 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
as a reg. front drag shock (non coil over)
Re: coil over front on a duster? [Re: BobsProFab] #169073
12/28/08 12:57 PM
12/28/08 12:57 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
HEY BOB, how much on the coil over shock's ????
Re: coil over front on a duster? [Re: B1Frank] #169074
12/28/08 01:00 PM
12/28/08 01:00 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
HEY BOB, how much on the shock's ????
just shocks or complete with springs and hardware.
these are sold as a shock ready for coil overs.
must buy the hardware kit also to install the spring.
