Post deleted by Defbob
[Re: duster408]
#169056
12/17/08 12:22 AM
12/17/08 12:22 AM
Re: coil over front on a duster?
#169057
12/17/08 01:52 AM
12/17/08 01:52 AM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
you can retain the stock LCA with the right mods. also think about shock tower bracing as DusterDave said, a must do ! i make a complete coil over conversion kit also to think about my website has details on the setup. Bondo
Re: coil over front on a duster? *DELETED*
[Re: duster408]
#169059
12/19/08 01:17 PM
12/19/08 01:17 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
Post deleted by QWK_ENUF_511
WAXER
[Re: duster408]
#169061
12/19/08 08:49 PM
12/19/08 08:49 PM
BobsProFab
sycamore,ohio
1. you will need to en large the shock bolt hole on the LCA, its only 7/16 needs to be 1/2 for the coil over bearing end and make a few 1/8 spacers to take up the extra room. 2. press out your LCA pivot shafts and machine a 3/8 x 24 thread into the back of them, that way you can retain the LCA from not wanting to pull loose from the pivot shaft, only the bushing is holding it on.locite it on with a washer to retain it. 3. brace the shock towers, it will want to twist the top of the frame rails in towards the motor and break the spot welds in the front frame rail in time. heres a pic of a new set of stock lower pivot shafts with a 3/8 x 24 thread in the back of them and a set of upper billet mounts heading Deigo Teds way i need the machine the spacers up for him yet Bondo
[Re: duster408]
#169065
12/21/08 02:26 PM
12/21/08 02:26 PM
#169066
12/21/08 02:47 PM
12/21/08 02:47 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
thanks, I also saw somewhere welding done on the LCA,s is this necessary?
Right here. Coil Over Conversion
Not to hi-jack, but do you guys think this is enough reinforcement for the uppers?
I don't know if I'm going to end up with the coil over deal or not, but before the car gets painted I want to make sure what I have would work...
[Re: duster408]
#169069
12/28/08 12:34 PM
12/28/08 12:34 PM
#169070
12/28/08 12:53 PM
12/28/08 12:53 PM
BobsProFab
sycamore,ohio
the best shock is the AFco M2/BNC direct fit drag shock that is coil over ready with 5 inch of travel. AFco is doing a awesome job at the mopar valving on these shocks which i have custom built and valved. a few pics of a M2 Bondo
[Re: B1Frank]
#169074
12/28/08 01:00 PM
12/28/08 01:00 PM
BobsProFab
sycamore,ohio
HEY BOB, how much on the shock's ????
just shocks or complete with springs and hardware.
these are sold as a shock ready for coil overs. must buy the hardware kit also to install the spring.
[Re: BobsProFab]
#169075
12/28/08 05:46 PM
12/28/08 05:46 PM
Posts: 3,009 Sac, CA
mopowers
Sac, CA
Do you sell the aluminum piece that replaces the bottom rubber/poly bushing on the top shock mount?
[Re: mopowers]
#169076
12/28/08 06:50 PM
12/28/08 06:50 PM
BobsProFab
sycamore,ohio
i turn them on the lathe out of 6061, the urethane bushing that comes with the shocks will not hold the weight when converted to coil over. they are fine for using them as a stock style front shock. I make them as needed, but if you need a set i can tool some up
[Re: Hot 340]
#169078
12/28/08 08:57 PM
12/28/08 08:57 PM
BobsProFab
sycamore,ohio
Yes, i put a ton of street miles on 340Ricks challenger this past summer (i think i put more miles on his car than he did in the past 10 years ) with my setup on it and the same coil overs with #250 springs the lighter spring seems to work well with me adding more per load to them for better reaction from the suspension. i can get you awesome deals on AFco products Bondo
[Re: BobsProFab]
#169079
12/28/08 09:50 PM
12/28/08 09:50 PM
BobsProFab
sycamore,ohio
3850M list 410.40 each : T2 5 inch drag coil over ready shock double adjustable. 23250CR list 68.69 each : coil over spring, this is what i run on Ricks car. 20124 list 47.55 each : coil over hardware kit. 20144 list 40.10 pair : bearing kit. thats $1,093.00 list on the front coil overs www.afcoracing.com and search the part #'s they are not cheap but one of the best shocks on the market today and AFco's customer service is second to none you can PM me for a killer price on a set Bondo
#169080
12/29/08 02:54 PM
12/29/08 02:54 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Ok I missing the boat here ! if you weld them LCA like that pic..how do the control arms move up and down ??
[Re: dizuster]
#169083
12/29/08 06:36 PM
12/29/08 06:36 PM
BobsProFab
sycamore,ohio
yes the LCA will try to bind. but on a budget it gets the job done. my setup has zero resitance
[Re: Plumb Wired]
#169085
12/29/08 11:42 PM
12/29/08 11:42 PM
mopowers
Sac, CA
The part you see welded is the adjuster that is no longer used once the torsion bar is eliminated. The weld just keeps what's left of the adjuster from moving around. I have whacked them off as close as possible then welded just for cosmetic purposes. Has nothing to do with the movement of the LCA.
Mike Gray
I think the confusion lies with the bolt and big washer that connects the LCA to the pivot pin. Once the adjuster is welded to the LCA and the pivot is bolted to both the LCA and the K-member it doesn't look like it should move.
It looks like Duster Dave used a nylon or teflon washer to allow the LCA to rotate up and down a little easier. It looks like that would free up some of the movement.
