Manual valve bodies... Do they improve ET? #1690219
10/25/14 12:18 AM
10/25/14 12:18 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi,
I am just curious... Does switching to a manual valve body in a transmission yield better ET, or is it more about consistency?
If they do get you better track times? What kind of gains do you see?
Mikey
1969 Dodge Dart Swinger
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690220
10/25/14 12:54 AM
10/25/14 12:54 AM
Renton Washington
Triple Threat Offline
Renton Washington
No gains unless you've got something wrong with the stock valve body. Just helps up the line pressure and offers more control to the driver.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Manual valve bodies... Do they improve ET? [Re: Triple Threat] #1690221
10/25/14 01:10 AM
10/25/14 01:10 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I don't understand how it couldn't help immensely.
You can shift firmer, less overlap, and quicker at the exact rpm the car likes( after trial and error).
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Manual valve bodies... Do they improve ET? [Re: B3422W5] #1690222
10/25/14 02:03 AM
10/25/14 02:03 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
I would think consistency as well, we will see if it improves ET tomorrow!
Mikey
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690223
10/25/14 02:08 AM
10/25/14 02:08 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
If you had an auto valve body that worked well and you converted it to a manual shift (forward pattern) you would see no difference at all. If you convert to a reverse manual valve body that has no low band apply you may notice a slightly better ET if what you had before had some overlap.
Many variables will determine the outcome of this question.
Hutch
Re: Manual valve bodies... Do they improve ET? [Re: Hutch] #1690224
10/25/14 02:13 AM
10/25/14 02:13 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Cool, thanks guys
Mikey
I will post results
Currently heap does 13.81 at 96 mph
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690225
10/25/14 04:13 AM
10/25/14 04:13 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Paul Forte at Turbo Action told me I could expect as much as 2 tenths going from a stock valve-body to the T/A manual..... I saw nothing. I'd make this mod again in a heartbeat, though. I used to struggle with finding the right throttle pressure setting. No worries on upshifts now, the next gear is always right there.
Re: Manual valve bodies... Do they improve ET? [Re: Hutch] #1690226
10/25/14 10:30 AM
10/25/14 10:30 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Hutch
Lets not forget that it takes hp to drive the pump at a higher pressure
Re: Manual valve bodies... Do they improve ET? [Re: BSB67] #1690227
10/25/14 10:38 AM
10/25/14 10:38 AM
gregsdart Offline
gregsdart  Offline
Firmer shifts and less overlap. That has to be worth something. In my case I was setting the 2nd gear band too tight, was worth half a tenth to get it right!
There can also be an overlap in manual low/2nd. That can be severe if a shift kit isn't done right.
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690228
10/25/14 11:15 AM
10/25/14 11:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cool, thanks guys
Mikey
I will post results
You will need to keep other variables as constant as possible to actually come to any clear conclusion. A couple of key variables are engine, water and oil temperature, 60 ft time, and atmospheric conditions. You will need the weather data from the past and the new track events so that you can adjust for these. Also, did you make ANY other changes to the car since your last outing?
Without holding these variables close, the manual VB might actually help, but the car slows .2, or it does not help at all, and the car picks up .3.
Be cautious on what you think you are learning.
Re: Manual valve bodies... Do they improve ET? [Re: StealthWedge67] #1690229
10/25/14 07:51 PM
10/25/14 07:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have seen many times a car pick up .2 but it depends on how bad off the other set was.
Re: Manual valve bodies... Do they improve ET? [Re: Quicktree] #1690230
10/26/14 11:21 AM
10/26/14 11:21 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Dang! I actually lost a bit best run14.2 at 95 mph
Mikey
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690231
10/26/14 02:01 PM
10/26/14 02:01 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Mikey
That's not because of the VB...you have something else going on...
If you can't handle the truth, you're living a lie.......
Re: Manual valve bodies... Do they improve ET? [Re: Big Squeeze] #1690232
10/26/14 04:05 PM
10/26/14 04:05 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Mikey
Hmmm, maybe back to what I said earlier.
Re: Manual valve bodies... Do they improve ET? [Re: BSB67] #1690233
10/26/14 07:19 PM
10/26/14 07:19 PM
Mopar drag engineers, Tom Hoover and others, did a lot of A,B,A tesing on many different valve bodies, shift kits and so on back in the late 1960 and early 1970s. T/A manual valve bodies at that time where measurably better than the rest out there back then I heard later that Winters came up with one that might have been .002 to .003 better than the T/A, maybe not due to weather and track changes in the time it takes to change the V.B. All of the LBA I've heard of are a little slower than the same brand no L.B.A. valve bodies More reasons to have a very good front drum instead of a stocker
Re: Manual valve bodies... Do they improve ET? [Re: Cab_Burge] #1690234
10/26/14 11:22 PM
10/26/14 11:22 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Totally agree with you all, but am kind of stumped. The car is nice, starts up nice, drives nice, but I feel like it is kind of a dog.. 14.2, with a best of 13.81, at 96 mph and I feel like it should have a lot more in it, then it does..
Mikey
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690235
10/27/14 12:36 AM
10/27/14 12:36 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
MPH was almost the same so we know the power was similar on both tests. Where in the run was all the ET lost?
Hutch
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690236
10/27/14 04:13 AM
10/27/14 04:13 AM
i've seen many, many aftermarket shifter cables mal or misadjusted, that flat eats up HP and transmissions, especially in our 727 and 904 I learned a long time ago to make sure the pin on the end of the cable end that rotates on the cable to adjust the length that fits into the shifter arm on the valve body drops in in nuetral, 1st, 2nd and 3rd gear. DROPS IN If it doesn't adjust the cable hieght and angle on the tranny bracket that hold the cable to the shifter arm until the cable end drops in by itself in all four positions Some the different shifters companys don't designate which way they want the pin to be install, from the top of the shifter arm or from the bottom, if your doesn't sometimes 1/2 a turn on the cable end will make the difference in dropping and not dropping Good luck , lets us know how it works out
Re: Manual valve bodies... Do they improve ET? [Re: Cab_Burge] #1690237
10/27/14 10:28 AM
10/27/14 10:28 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hutch,
Believe it or not but my 60 foot time, my best was 2.2. Also, Cab I agree I am always worried about TF linkage, so I had my transmission guy help set it up correctly.
My concern is HP in general
A 9:1 440 with decent 915 heads, headers, 703 lunati cam, Holley dominator intake,and 750 carb , SHOULD be able to push a car into low 13's at
Least..
Re: Manual valve bodies... Do they improve ET? [Re: MikeyT] #1690238
10/27/14 11:31 AM
10/27/14 11:31 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Get some DOT stickies and watch how quick you times drop. Don't worry about et. Get that 60ft down and your et's will drop quickly.
