TA / AAR rear spring & shocks part #s #1689806
10/23/14 10:46 PM
10/23/14 10:46 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
The build sheet on my T/A shows rear spring last 3 digits of 048. I could not find any spring that ends in 048 in the master parts book. Also my build sheet shows the rear shocks last 2 digits of 54 which I think might be the standard 340 spring (3400854). I thought these car got the C body rear shocks with the longer travel.
Re: TA / AAR rear spring & shocks part #s [Re: ragtop] #1689807
10/23/14 10:49 PM
10/23/14 10:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Rear spring numbers are 3400048 - it is in each bottom leaf.
54 shocks were used on 340 4-bbl Challengers also. I have not heard of them being used on C-bodies?
Re: TA / AAR rear spring & shocks part #s [Re: Alaskan_TA] #1689808
10/23/14 11:00 PM
10/23/14 11:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cuda 340 also used the 54.
Re: TA / AAR rear spring & shocks part #s [Re: Alaskan_TA] #1689809
10/24/14 12:10 AM
10/24/14 12:10 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Thanks Barry. So T/As got regular 340 rear shocks and not the longer ones from a C body? Thanks again.
Re: TA / AAR rear spring & shocks part #s [Re: ragtop] #1689810
10/24/14 03:02 AM
10/24/14 03:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
trans am cars used the lower shock brackets from a b-body to help compensate for the raised rear
Re: TA / AAR rear spring & shocks part #s [Re: 6bblgt] #1689811
10/24/14 10:46 AM
10/24/14 10:46 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The spring mounts came up back in 2003, so I looked under several AARs & T/As that year. There were two different spring mounts used in real life, not sure why.
There is also a handwritten document from someone inside the program that says
Rear Spring 340048 with "C" body spring plates
I will look for other references to it as time allows, thanks for the book Frank!
Re: TA / AAR rear spring & shocks part #s [Re: 6bblgt] #1689812
10/25/14 06:42 PM
10/25/14 06:42 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I could not find any different lower shock brackets in the 1970-71 Master Parts catalog for B or C bodies?
Re: TA / AAR rear spring & shocks part #s [Re: ragtop] #1689813
10/25/14 10:12 PM
10/25/14 10:12 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
The use of the b-body spring plate was to allow the 054 shocks to still work. Chrysler did this to compensate for the different arch in the springs and allow the 054 shocks to still work.
performancecarrestorations.com
Re: TA / AAR rear spring & shocks part #s [Re: moparo] #1689814
10/26/14 02:07 PM
10/26/14 02:07 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
What is the correct part number for the front shocks?
