front suspension #1689555
10/23/14 01:12 AM
10/23/14 01:12 AM
long island new york
K
kingdust Offline OP
kingdust  Offline OP
K
does anybody make a tubular k frame for torsion bars anymore? seems you can only get one with coil overs. thanks MARK
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: front suspension [Re: kingdust] #1689556
10/23/14 01:25 AM
10/23/14 01:25 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
QA1
Re: front suspension [Re: SpareParts] #1689557
10/23/14 09:40 AM
10/23/14 09:40 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Beware of poor fit.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: front suspension [Re: 1967dartgt] #1689558
10/27/14 11:55 PM
10/27/14 11:55 PM
K
kingdust Offline OP
kingdust  Offline OP
K
Beware of poor fit.
poor fit from the qa1? I know I had a few friends with the magnum force early stuff that didn't fit good. I think that's corrected now. I want to run stock susp. classes so not sure if the coil overs would kill that.
Re: front suspension [Re: kingdust] #1689559
10/28/14 12:00 AM
10/28/14 12:00 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mark, I have seen some highly modded stock K's
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: front suspension [Re: kingdust] #1689560
10/28/14 12:05 AM
10/28/14 12:05 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Usually coilovers are okay as long as they tie into the stock mounting points. Check the rules to be sure.
Most of them equate to the 4 K member bolts still mount the K, the UCA uses the stock mounting points, and the shock mounts to the stock point on the body which will need to be braced to support the weight of the car.
Re: front suspension [Re: kingdust] #1689561
10/28/14 12:06 AM
10/28/14 12:06 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Beware of poor fit.
No doesn't effect it. Your shock is in stock location along with both of your control arms.
Re: front suspension [Re: hemi-itis] #1689562
10/28/14 12:15 AM
10/28/14 12:15 AM
K
kingdust Offline OP
kingdust  Offline OP
K
hey al whats up? yea mine is modded already and I have another completely stock one that I might modify. the one I have in the car is the original one and its beat up pretty bad. the front frame rail was bent way back in the mid 80s and I had willy hasik straiten out and align it but he also welded the k frame to the rail on the pass side front. so I want to fix all that mess.
Re: front suspension [Re: SpareParts] #1689563
10/28/14 12:20 AM
10/28/14 12:20 AM
K
kingdust Offline OP
kingdust  Offline OP
K
ok well that makes sense. makes my decision a little more easy. thanks.MARK
Re: front suspension [Re: 1967dartgt] #1689564
10/28/14 12:25 AM
10/28/14 12:25 AM
K
kingdust Offline OP
kingdust  Offline OP
K
Beware of poor fit.
thanks for the info. it will be more money but better in the long run. so as long as everything is at its stock locating points its good to go! thanks MARK
