Re: The best CNC head porting shop???
[Re: 1320Dart]
#1689170
10/23/14 05:42 PM
10/23/14 05:42 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Modern Cylinder Head gets my business.
What type of heads do you have them do?
My W8 small block heads.
[Re: ]
#1689171
10/23/14 05:45 PM
10/23/14 05:45 PM
Sammy
Wind Gap,Pa.
FHO has a pretty good Hemi program.
They did my stage V big valve hemi heads.
I bet you paid over $2500.00 to get those heads ported from FHO? Compare that to Modern Cylinder Head.
[Re: 1320Dart]
#1689172
10/23/14 06:01 PM
10/23/14 06:01 PM
Posts: 369 Indy
496 A-body
Indy
yes you can start with ports on a head that have been digitized. Then use that digitized model as your "blueprint". A good machinist/programmer will go in and alter that model to make it better. Then keeps changing it as the data comes in and logs the data to what works and doesn't to better the head.
My exposure to digitized/3D scanned parts begins as a point cloud file that is then converted to surfaces. My life would be much easier if I had CNC machinists that were skilled enough to modify surface data. Guys like you are few and far between.
[Re: 1320Dart]
#1689177
10/23/14 07:10 PM
10/23/14 07:10 PM
BradH
I don't care how good of a programer you may or may not be nothing replaces flow bench and track testing.
totally
But with the proper feedback and the right machinist and or programmer it would be darn close right off the machine.
We get it: you REALLY like CNC porting.
You don't seem to get it: CNC ain't sh!t if the original hand-carved port isn't right.
It's funny to hear over on SpeedTalk how the guys that do port development go to PRI, etc., and see all these pretty CNC-ported heads that have crappy port & chamber designs... but they LOOK good!
[Re: 1320Dart]
#1689182
10/23/14 08:16 PM
10/23/14 08:16 PM
BradH
... But according to other people on this post, button pusher CNC guys like myself, aren't smart enough to fix a bad flowing port. Only a guy with a fast spinning piece of sandpaper on the end of a stick is. That's other peoples opinion
If you have a flow bench, the proper tools to map the velocity changes that go along with subtle changes to the port, the knowledge of how & where to change the port to address deficiencies in the velocity profile & flow patterns AND the ability to translate those changes to the code to revise the tool path w/o having to physically change the original port and re-digitize it, then you're good to go!
I'll have to ask Chad Speier and Curtis Boggs how they like being referred to as "a guy with a fast spinning piece of sandpaper on the end of a stick".
[Re: 1320Dart]
#1689184
10/23/14 10:05 PM
10/23/14 10:05 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So would you replace my heads when the change you made didn't work? Or fix them? I pay for a cnc port because it is proven on the flow bench. And if it isn't hand touched up you have a bad head guy.
Brett Miller W9 cnc'd heads STR Chassis fabraction
