Page 3 of 4 1 2 3 4
Re: The best CNC head porting shop??? [Re: Monte_Smith] #1689168
10/23/14 04:23 PM
10/23/14 04:23 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Most CNC programs don't evolve as quickly as port designs do. Meaning that "trick" CNC porting job you get, may be a 5 year old program...................BUT, there is nothing wrong with that. I still buy CNC ported heads and then send them to "my guy" to fix them. The added cost of the CNC porting is usually less than having bare castings done completely by hand.
Monte
I love my job. I love technology period. In our "racing life" we don't use it to its potential IMO.
That's why I started this post was to find out who is leading the way on the CNC side of things.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: The best CNC head porting shop??? [Re: pittsburghracer] #1689169
10/23/14 05:32 PM
10/23/14 05:32 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Hand porting and porters is becoming a "lost art". CNC programers copy and use a hand ported head as a blueprint good or bad. I reworked a set of AFR cnc'd chevy heads that weren't worth crap and WAY off their advertized flow numbers. Hand porting is NOT easy work.
yes you can start with ports on a head that have been digitized. Then use that digitized model as your "blueprint".
A good machinist/programmer will go in and alter that model to make it better. Then keeps changing it as the data comes in and logs the data to what works and doesn't to better the head.
Greg
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689170
10/23/14 05:42 PM
10/23/14 05:42 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Modern Cylinder Head gets my business.
What type of heads do you have them do?
My W8 small block heads.
Re: The best CNC head porting shop??? [Re: ] #1689171
10/23/14 05:45 PM
10/23/14 05:45 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
FHO has a pretty good Hemi program.
They did my stage V big valve hemi heads.
I bet you paid over $2500.00 to get those heads ported from FHO?
Compare that to Modern Cylinder Head.
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689172
10/23/14 06:01 PM
10/23/14 06:01 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
My exposure to digitized/3D scanned parts begins as a point cloud file that is then converted to surfaces. My life would be much easier if I had CNC machinists that were skilled enough to modify surface data. Guys like you are few and far between.
Re: The best CNC head porting shop??? [Re: 496 A-body] #1689173
10/23/14 06:18 PM
10/23/14 06:18 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I just assumed that any shop that was CNC porting heads knew how to do all this stuff. Then the shops that weren't making the necessary adjustments to better their product, were in it for the quantity not the quality.
That's another reason I started this post. I wanted to be able to weed those shops out from my selection.
Greg
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689174
10/23/14 06:21 PM
10/23/14 06:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don't care how good of a programer you may or may not be nothing replaces flow bench and track testing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The best CNC head porting shop??? [Re: pittsburghracer] #1689175
10/23/14 06:31 PM
10/23/14 06:31 PM
tboomer Offline
tboomer  Offline
I am quite happy with my Victors that were done by Roger(Radar)Lechtenberg. He did mine by hand. His flow bench is pretty tight. He learned the trade from Gary Ostrich. He has been going ever since. I have seen him and a John Deere engineer carve a cylinder head from a block of aluminum. Do a google search on him. He was also in on the design of a BB mopar head. Never saw a dime from that.
Re: The best CNC head porting shop??? [Re: pittsburghracer] #1689176
10/23/14 06:48 PM
10/23/14 06:48 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
totally
But with the proper feedback and the right machinist and or programmer it would be darn close right off the machine.
Greg
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689177
10/23/14 07:10 PM
10/23/14 07:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
totally
We get it: you REALLY like CNC porting.
You don't seem to get it: CNC ain't sh!t if the original hand-carved port isn't right.
It's funny to hear over on SpeedTalk how the guys that do port development go to PRI, etc., and see all these pretty CNC-ported heads that have crappy port & chamber designs... but they LOOK good!
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689178
10/23/14 07:20 PM
10/23/14 07:20 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
totally
Are you using a CAD or CAM software for surface modification? If CAM which one? Just curious how you do surfaces with the majority of them (especially a port) being not true geometry.
As far as most CNC porting shops, the way I understand it is they take one hand ported intake and exhaust port (could be great, could be crap)have it scanned and then pattern and mirror it for the head. Doubt they have a CAD user who can manipulate the model to counteract core shift. Maybe Modern can chime in on this.
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689179
10/23/14 07:21 PM
10/23/14 07:21 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
IMHO You have to pick what's right for you. There's no one size fits all.
Use the heads out of the box which many do.
Have a guy spend a few hours on the as cast ports. Usually good gains to be had there.
CNC port at a reputable shop. Good value really since the guides, deck, chambers valve job and ports are all done at the same time. That $1000 for a CNC port job is really $1000 for head to have everything corrected plus ported.
CNC port and hand finish if you're going all out.
My experience with the 4 sets of CNC heads I've had done so far is that they push the limits of the casting and fix where the limit was exceeded. My Buick heads had tubes in half the push rod holes because they broke through. My edelbrock heads went into the rocker studs. I was talking to the guy who did my Buick engines last weekend and he ceramic seals every set of heads he has CNC'd. Insurance against leaks knowing the casting limits are getting pushed.
Re: The best CNC head porting shop??? [Re: BradH] #1689180
10/23/14 07:40 PM
10/23/14 07:40 PM
AndyF Online content
AndyF  Online Content
That is why my answer back on page 1 was to talk to Dwayne. He gets a lot of heads in his shop and probably has seen most everything. If anyone would know which CNC programs are working he would.
Re: The best CNC head porting shop??? [Re: 496 A-body] #1689181
10/23/14 08:02 PM
10/23/14 08:02 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
totally
I personally own and use my software's at the place I work at. They are SolidWorks and CamWorks. I feel they are great softwares together. FWIW, CP Pistons also uses CamWorks for their stuff too.
But also to counteract core shift, you need to know if it is shifted in the first place and how much and which way. If you're going full out on the porting, the head needs to be sonic checked or x-rayed first. Not just bolt the head down and push the cycle start button. IMO.
Yes, you do need to be able to counteract core shift by manipulating the solid model a bit. Also just MO.
But according to other people on this post, button pusher CNC guys like myself, aren't smart enough to fix a bad flowing port. Only a guy with a fast spinning piece of sandpaper on the end of a stick is. That's other peoples opinion
Greg
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689182
10/23/14 08:16 PM
10/23/14 08:16 PM
BradH Offline
BradH  Offline
... But according to other people on this post, button pusher CNC guys like myself, aren't smart enough to fix a bad flowing port. Only a guy with a fast spinning piece of sandpaper on the end of a stick is. That's other peoples opinion
If you have a flow bench, the proper tools to map the velocity changes that go along with subtle changes to the port, the knowledge of how & where to change the port to address deficiencies in the velocity profile & flow patterns AND the ability to translate those changes to the code to revise the tool path w/o having to physically change the original port and re-digitize it, then you're good to go!
I'll have to ask Chad Speier and Curtis Boggs how they like being referred to as "a guy with a fast spinning piece of sandpaper on the end of a stick".
Re: The best CNC head porting shop??? [Re: BradH] #1689183
10/23/14 08:41 PM
10/23/14 08:41 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
That's why I stated earlier about getting proper feedback and tracking data. That all goes under the proper tools. A good programmer just doesn't go in and change a program just to change it. They need feedback and justification and they jump right on it. You and I are saying the same things I feel. Just seeing it differently I guess.
Greg
Re: The best CNC head porting shop??? [Re: 1320Dart] #1689184
10/23/14 10:05 PM
10/23/14 10:05 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So would you replace my heads when the change you made didn't work? Or fix them? I pay for a cnc port because it is proven on the flow bench. And if it isn't hand touched up you have a bad head guy.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: The best CNC head porting shop??? [Re: pittsburghracer] #1689185
10/23/14 11:18 PM
10/23/14 11:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Did Shady Dell ever get a cnc machine??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: The best CNC head porting shop??? [Re: hemi-itis] #1689186
10/24/14 02:51 AM
10/24/14 02:51 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
CNC ported heads are still the way to go, because it saves SO MUCH hand work. Most Pro-Stock engine builders order CNC ported castings from CFE by the pallet and then put THEIR touches on it. I have a friend who does Pro-Stock heads and he said he may have 8 hrs in a set of ready to go PS heads now, where he used to spend a week when he started with as cast stuff.
But as stated before, CNC heads should still he touched up by hand for best performance. As an example, I just bought a brand new set of 14* CNC ported Big Chiefs from one of the most well known head shops out there. And even though port and chamber designs have come a long way in the past few years, these heads were identical to the 14* heads I bought from the same company about 6 years ago. That's what I meant about a LOT of companies don't update their programs on a regular basis.
Monte
Re: The best CNC head porting shop??? [Re: d7cook] #1689187
10/24/14 07:52 AM
10/24/14 07:52 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Anyone ever use this place? Wondering how their program is for max wedged BB RPM heads.
http://www.rmcompetition.com/cylinder-heads-.html
Page 3 of 4 1 2 3 4
