Re: da shocks on cal trac suspension
[Re: Don_440]
#1688716
10/21/14 10:09 PM
10/21/14 10:09 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have afco from Mark Menser. Made car car way more manageable and consistent. It went from 1.45s to a best of a 1.31. Goes 1.32-4 all the time.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1688717
10/21/14 10:50 PM
10/21/14 10:50 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Where's your set Brad? I'm getting mixed opinions. Some say loosen them up, others say tighten them up. I'm
[Re: Don_440]
#1688718
10/21/14 10:52 PM
10/21/14 10:52 PM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
Afco here as well....1.41 best with Rancho 9 ways to 1.33 best with the Afcos. Very consistant 1.34 to 1.35 on decent prepped track. I had added rear sliders as well during the shock change over.
Brett Miller 447 W9
[Re: Don_440]
#1688725
10/22/14 10:19 AM
10/22/14 10:19 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
My Rancho 9 ways worked OK at 800 hp, but now not so much w/ 1000+ hp. I'm going w/ D/A shocks front and rear...probably going to give Viking shocks a try.
[Re: Don_440]
#1688728
10/22/14 12:26 PM
10/22/14 12:26 PM
Posts: 7,506 Az
Crizila
Az
I use cal trac shocks with my single leaf cal trac set up. No matter what shock you use, there is no one single adjustment that is right for all occasions. This includes the bar adjustments also. Besides 60 foot times, shock / bar adjustments can also effect reaction times - especially the bars ( tight to loose ). Running tie-wraps on your shock pistons can give you an idea of shock travel change when you change settings.
Fastest 300
Re: Fast Shocks
[Re: Dyno1]
#1688730
10/23/14 12:14 AM
10/23/14 12:14 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
wasn't there a dealer for Afco on here?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: hemi-itis]
#1688732
10/23/14 09:44 AM
10/23/14 09:44 AM
1967dartgt
Hilltown Pa
Has anyone had good luck with the Vikings shocks yet? The two that I have spoken too haven't had any success.
[Re: 1967dartgt]
#1688733
10/23/14 10:24 AM
10/23/14 10:24 AM
an8sec70cuda
hemi-itis...thanks, will do! 1967dartgt...From what I've read on YB they get good reviews. Some small tire guys in NC have had good luck w/ them too. Guess I'll see how they work next year...they're gonna be a Christmas present to myself.
