da shocks on cal trac suspension #1688715
10/21/14 07:43 PM
10/21/14 07:43 PM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
Just wanting to know who is usind them, what brand,how much better did you car repond. thanks don
Re: da shocks on cal trac suspension [Re: Don_440] #1688716
10/21/14 10:09 PM
10/21/14 10:09 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have afco from Mark Menser. Made car car way more manageable and consistent. It went from 1.45s to a best of a 1.31. Goes 1.32-4 all the time.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688717
10/21/14 10:50 PM
10/21/14 10:50 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Where's your set Brad?
I'm getting mixed opinions. Some say loosen them up, others say tighten them up. I'm
Re: da shocks on cal trac suspension [Re: Don_440] #1688718
10/21/14 10:52 PM
10/21/14 10:52 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Afco here as well....1.41 best with Rancho 9 ways to 1.33 best with the Afcos. Very consistant 1.34 to 1.35 on decent prepped track.
I had added rear sliders as well during the shock change over.
Brett Miller 447 W9
Re: da shocks on cal trac suspension [Re: Don_440] #1688719
10/21/14 11:08 PM
10/21/14 11:08 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
afco's here .
the front one's helped my car a lot .
was doing 3+ft. wheelie's now down to about a foot.
Re: da shocks on cal trac suspension [Re: mcduff] #1688720
10/22/14 01:36 AM
10/22/14 01:36 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A shock absorber on a race car only has two functions. On the rear they control the housing and on the front they control the rate of rise. On both ends they help keep the tire on the track with compression settings. The more power you make, the better shock you need. If you think $100 shocks will control the ends of the car just as good as a $1000 shock.......well that is just nowhere close to right. Many guys think, my car only runs "so and so" I don't need good shocks. Wrong again......LOL!!! Look under some of the slower stockers. They have GOOD shocks, there is a reason for that.
Now, what shocks you NEED, more or less depend on what you are willing to spend. One thing to keep in mind though. The trickest suspension in the world won't work right without good shocks
Monte
Re: da shocks on cal trac suspension [Re: Monte_Smith] #1688721
10/22/14 01:46 AM
10/22/14 01:46 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
anybody got a part # for the afco's?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: da shocks on cal trac suspension [Re: Stroker Scamp] #1688722
10/22/14 02:06 AM
10/22/14 02:06 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
3890M rear
3850M front
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688723
10/22/14 07:53 AM
10/22/14 07:53 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I called him... Quite surprised on cost per pair.
Mopar Performance
Re: da shocks on cal trac suspension [Re: moparniac] #1688724
10/22/14 08:22 AM
10/22/14 08:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The $ that Diszuster spent with Menser was saved in the less track time, He spent more $ testing trying to get his 62 to hook. We're just scratching the surface so far. Went from having to be backed off to keep from spinning mid 1.6 to consistent 1.40. Look at how many rounds the turbo 62 went in the events it was entered in this year. Money well spent.
Doug
Re: da shocks on cal trac suspension [Re: Don_440] #1688725
10/22/14 10:19 AM
10/22/14 10:19 AM
an8sec70cuda Offline
My Rancho 9 ways worked OK at 800 hp, but now not so much w/ 1000+ hp.
I'm going w/ D/A shocks front and rear...probably going to give Viking shocks a try.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: da shocks on cal trac suspension [Re: Sammy] #1688726
10/22/14 11:13 AM
10/22/14 11:13 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Tighten them up.
Re: da shocks on cal trac suspension [Re: moparniac] #1688727
10/22/14 11:19 AM
10/22/14 11:19 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Send your set in to get new valves. Its what I did.
Re: da shocks on cal trac suspension [Re: Don_440] #1688728
10/22/14 12:26 PM
10/22/14 12:26 PM
Az
Crizila Offline
Crizila  Offline
Az
I use cal trac shocks with my single leaf cal trac set up. No matter what shock you use, there is no one single adjustment that is right for all occasions. This includes the bar adjustments also. Besides 60 foot times, shock / bar adjustments can also effect reaction times - especially the bars ( tight to loose ). Running tie-wraps on your shock pistons can give you an idea of shock travel change when you change settings.
Fastest 300
Fast Shocks [Re: Crizila] #1688729
10/22/14 03:04 PM
10/22/14 03:04 PM
Dyno1 Offline
Dyno1  Offline
Call Randy at Fast Shocks, 612-306-5387, he is a dealer and racer. He has Afco and Penske and can custom build anything you need. He has helped many well known racers from across the USA. Well worth the call. Dyno
Re: Fast Shocks [Re: Dyno1] #1688730
10/23/14 12:14 AM
10/23/14 12:14 AM
pacific northwest
pacific northwest
wasn't there a dealer for Afco on here?
Re: da shocks on cal trac suspension [Re: an8sec70cuda] #1688731
10/23/14 12:50 AM
10/23/14 12:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also Bought set of Vi-kings direct from Chris.Let him know I sent you. Customer survice is beond reproch
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: da shocks on cal trac suspension [Re: hemi-itis] #1688732
10/23/14 09:44 AM
10/23/14 09:44 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Has anyone had good luck with the Vikings shocks yet? The two that I have spoken too haven't had any success.
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688733
10/23/14 10:24 AM
10/23/14 10:24 AM
hemi-itis...thanks, will do!
1967dartgt...From what I've read on YB they get good reviews. Some small tire guys in NC have had good luck w/ them too. Guess I'll see how they work next year...they're gonna be a Christmas present to myself.
CHIP
Re: da shocks on cal trac suspension [Re: 1967dartgt] #1688734
10/23/14 09:47 PM
10/23/14 09:47 PM
hemi-itis Offline
hemi-itis  Offline
Please elaborate
