Front spring hanger Reinforcing Plate #1688401
10/20/14 09:04 PM
10/20/14 09:04 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
Installing a set of SS springs using the required front spring hangers on an E-body. I see there are reinforcing plates available. I don't need them for spacing purpose. However, is it recommended to use them on the backside of the front hanger for added reinforcement or are they not necessary?
http://chucker54.stores.yahoo.net/ebospharepl.html
Re: Front spring hanger Reinforcing Plate [Re: cruzin] #1688402
10/20/14 09:33 PM
10/20/14 09:33 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I made my own? Thinking it adds strength?
Re: Front spring hanger Reinforcing Plate [Re: cruzin] #1688403
10/20/14 09:34 PM
10/20/14 09:34 PM
AndyF Online content
AndyF  Online Content
The factory put them on the higher powered cars. Seems prudent to reinforce that area since there is so much stress there.
Re: Front spring hanger Reinforcing Plate [Re: AndyF] #1688404
10/20/14 10:37 PM
10/20/14 10:37 PM
NY NY
3
340duster340 Offline
NY NY
that being said, how does it help? its not load bearing, so unless your concerned with spring hangers pulling out, i don't understand what they do.
Re: Front spring hanger Reinforcing Plate [Re: 340duster340] #1688405
10/21/14 12:04 AM
10/21/14 12:04 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
sometimes i just like overkill, one less thing to worry about
Re: Front spring hanger Reinforcing Plate [Re: cruzin] #1688406
10/21/14 12:41 AM
10/21/14 12:41 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Silly me, I thought they were spacers to align the rear.
Re: Front spring hanger Reinforcing Plate [Re: jcc] #1688407
10/21/14 02:23 AM
10/21/14 02:23 AM
They are reproductions of the original stiffening plates but you can use them as shims to adjust the rear thrust angle if necessary. Works for either application.
Re: Front spring hanger Reinforcing Plate [Re: cruzin] #1688408
10/21/14 01:02 PM
10/21/14 01:02 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I could see them as a benefit to drag cars with sticky tracks and gripping slicks that are trying to pull the hanger out of its mounting pocket. Not unlike a roll bar reinforcing plate that spreads load over a wider area.
Re: Front spring hanger Reinforcing Plate [Re: TC@HP2] #1688409
10/21/14 01:10 PM
10/21/14 01:10 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I thought the load was more compression, especially for drag situations?
Re: Front spring hanger Reinforcing Plate [Re: cruzin] #1688410
10/21/14 01:44 PM
10/21/14 01:44 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
That is where we connect our subframe connectors, with a similar plate. Transfers the load and really adds to the chassis rigidity and control.
Re: Front spring hanger Reinforcing Plate [Re: jcc] #1688411
10/22/14 01:26 PM
10/22/14 01:26 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Its more of a sheer load on the front hanger, although it may be slightly compressive for the top two hanger studs and slightly expansive on the bottom two studs.
If you look at housing rotation on a launch, this pulls the front spring segment up, which pulls the spring eye up, which pulls the mounting bracket up, and because the mopar hanger is not symetrical, it pulls on the bottom studs and pushes on the top studs.
If you use a Cal-trac type device, it resists compressive loading, but this is due to the housing rotation around the axle that would compress anything mounted under the axle centerline.
The reinforcing plates are not a bad addition if you want them.
Re: Front spring hanger Reinforcing Plate [Re: TC@HP2] #1688412
10/22/14 06:01 PM
10/22/14 06:01 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I would *think* there is quite some more compression and forward 'push' to this area, in addition to an upward force.
As after 'all' the things have happened like TC@HP2 has mentioned above, finally the rear axle/leafsprings start pushing the entire weight of the car forward.
Re: Front spring hanger Reinforcing Plate [Re: BigBlockMopar] #1688413
10/23/14 12:16 AM
10/23/14 12:16 AM
Yes and then when you hit the brakes hard the weight of the car is being pulled back by the spring hanger which is bolted to a couple thicknesses of sheet metal.
And when you go around a corner the car body is held in place by those same bolts.
Re: Front spring hanger Reinforcing Plate [Re: AndyF] #1688414
10/23/14 10:17 AM
10/23/14 10:17 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
But to be accurate, the braking forces will never equal acceleration forces in this location.
