Re: GEN III Hemi assembly drive setup???
[Re: mshred]
#1688177
10/20/14 11:46 PM
10/20/14 11:46 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
as this is something I am interested in as well!
I remember reading that truck timing covers suuposedly work better in the older chassis' but I can't recall why
Car timing covers put the alt down low, the truck covers put them up pretty high. Depending on the chassis, at least B/E/A, the car cover is more sought-after.
You can see where the truck cover sticks things on this one out of an '06 Ram
[Re: KRYPTONITE]
#1688182
10/21/14 12:04 PM
10/21/14 12:04 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
STEFF
Nice Clean Set up
What water pump are you using? and Motor plate??
Thanx!! Meziere Remote Mount Water Pump, mounted on a bracket that goes from the k-frame to the core support, under the radiator. I made the motor plate.
[Re: KRYPTONITE]
#1688184
10/21/14 02:32 PM
10/21/14 02:32 PM
STEFF
I dont understand this part- mounted on a bracket that goes from the k-frame to the core support, under the radiator
sorry Steff,
I looked to see if I had a pic of it and I don't. I can post one later when I get home from work.
[Re: KRYPTONITE]
#1688186
10/21/14 04:55 PM
10/21/14 04:55 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
If you need gen3 alternator brackets or motorplates, I have them in stock. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
