72 Challenger Power to Manual Disc Brakes? #1687934
10/19/14 06:08 PM
10/19/14 06:08 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Posting for a buddy of mine who wants to swap the factory power unit to manual setup. Anyone done this and if so what master works properly, and what other parts required if any?
Re: 72 Challenger Power to Manual Disc Brakes? [Re: SCATPK] #1687935
10/19/14 10:13 PM
10/19/14 10:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You need an E-body manual push-rod, firewall stiffening plate and manual master cylinder.
I stock all of these parts. As far as I know, I am the only source for a repro E-body manual firewall stiffening plate.
http://www.doctordiff.com/brakes/components-en/
Re: 72 Challenger Power to Manual Disc Brakes? [Re: DoctorDiff] #1687936
10/20/14 05:11 PM
10/20/14 05:11 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Is the master you have available the newer style and if so any issues with leaking from the caps? I have a master that looks similar to the pics on your website on my dart and the caps seep fluid. I appreciate your reply to my questions.
Re: 72 Challenger Power to Manual Disc Brakes? [Re: SCATPK] #1687937
10/20/14 07:44 PM
10/20/14 07:44 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rockauto shows a manual disc brake master cylinder for a 1974 Challenger.
Re: 72 Challenger Power to Manual Disc Brakes? [Re: SCATPK] #1687938
10/21/14 12:42 AM
10/21/14 12:42 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, I stock the newer style 1 1/32" and 15/16" bore aluminum master cylinders.
If your caps leak, I recommend replacing them with a pair of Dorman # 42044.
Re: 72 Challenger Power to Manual Disc Brakes? [Re: DoctorDiff] #1687939
10/22/14 02:01 AM
10/22/14 02:01 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Thanks for the info guys! What size master would be best for minimal braking effort.
Re: 72 Challenger Power to Manual Disc Brakes? [Re: DoctorDiff] #1687940
10/22/14 06:14 AM
10/22/14 06:14 AM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
I don't see the E body manual pushrod??
Re: 72 Challenger Power to Manual Disc Brakes? [Re: SCATPK] #1687941
10/22/14 09:06 AM
10/22/14 09:06 AM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Smaller bore master cylinders equals less effort, but also requires more travel.
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: 72 Challenger Power to Manual Disc Brakes? [Re: Sir Valiant] #1687942
10/22/14 03:44 PM
10/22/14 03:44 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't list the E-body adjustable push rod on my web-site.
If you are interested, please call for more information.
