Modified Early B Body K Member #1687748
10/19/14 01:37 PM
10/19/14 01:37 PM
Central California
MoParFish Offline OP
Central California
Just figured I'd share a couple of before and after pics of a spare early B-body K member I just finished for my 64. Was 42.25 lbs, Now 29.60 lbs on the fedex scale. Main goal was to be able to remove pan with engine in car but I'll take the over 12 pounds of weight savings too. I'm adding a motor plate but removing motor mounts, brackets and limiter(chain) so I imagine it may be wash there, weight wise...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Modified Early B Body K Member [Re: MoParFish] #1687749
10/19/14 01:38 PM
10/19/14 01:38 PM
Central California
Central California
After
Re: Modified Early B Body K Member [Re: MoParFish] #1687750
10/19/14 04:05 PM
10/19/14 04:05 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Looks good. There is alot of material gone there. Are you going with a mid plate or ears?
Re: Modified Early B Body K Member [Re: MoParFish] #1687751
10/19/14 04:06 PM
10/19/14 04:06 PM
Az
Crizila Offline
Crizila  Offline
Az
Looks great! With solid mounts, should work fine and make life a lot easier.
Fastest 300
Re: Modified Early B Body K Member [Re: Crizila] #1687752
10/19/14 04:48 PM
10/19/14 04:48 PM
Central California
Central California
Thanks! I've got an AndyF motor plate for it. I'll start swapping it all out soon. Just wanted to get the other K member ready before I dismantled the car. Currenly has shimmed up stock motor mounts and an "old school" chain to hold it down. Moves around a lot...Mods are long overdue...
Re: Modified Early B Body K Member [Re: MoParFish] #1687753
10/19/14 09:21 PM
10/19/14 09:21 PM
fullmetaljacket Offline
Great job MoFish
Did you peep DVW's K member build on the "Real World weight loss program and cost"? I think he even trimmed and closed seam welded the outer continental shelves and saved an additional couple of pounds.
I was thinking for a real stock look that your K as it is now can have the parts that were cut out be fabricated out of super thin metal and reinstalled so that it looks totally stock. I bet the F.A.S.T crowd has already done this.
Re: Modified Early B Body K Member [Re: fullmetaljacket] #1687754
10/19/14 10:27 PM
10/19/14 10:27 PM
Central California
Central California
Great job MoFish
Thanks! I keep meaning to read the entire "real world weight loss" thread. I guess I should check it out.
Re: Modified Early B Body K Member [Re: MoParFish] #1687755
10/19/14 10:49 PM
10/19/14 10:49 PM
It's encyclopedia thick at this point. Too much to read but a bible of source. DVW is senior to us all, but also the most neat and pro built unit in the whole thread.
I do wish I could find the Holy grail of K-members which is a stainless AFX unit. There's one on E-pray at $14K.
I believe the factory had it down to 17 lbs. But prone to cracking from violent wheel stands. Even heard in urban legend that magnesium examples existed probably just like Big foot.
Re: Modified Early B Body K Member [Re: MoParFish] #1687756
10/20/14 12:41 AM
10/20/14 12:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After
Looks great and have considered this deal myself............
Re: Modified Early B Body K Member [Re: MoParFish] #1687757
10/20/14 11:37 AM
10/20/14 11:37 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
After
Hate to be negative here but it looks like it will flex since one of its purposes was to tie the frame together. Are you still using the stock steering? That steering box will move with no more support than shown, maybe consider using a r&p. I'm all for saving weight too but the k-frame is a critcal support of the car and components. Flex at speed gets scary real fast.
Re: Modified Early B Body K Member [Re: cudaman1969] #1687758
10/20/14 12:06 PM
10/20/14 12:06 PM
Central California
Central California
After
That was one of my concerns too. It's one of the reasons I left all the flange lips in place. Stock steering for now. I may add another brace to tie steering box plate in a little better. I will be keeping a close eye on it all.
Re: Modified Early B Body K Member [Re: MoParFish] #1687759
10/20/14 12:12 PM
10/20/14 12:12 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
After
No flexing issues the way you have it. On mine I did cut off around the steering mount but did add a gusset for strengh.
Re: Modified Early B Body K Member [Re: max_maniac] #1687760
10/20/14 12:22 PM
10/20/14 12:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
After
Sorry, I have to question that outright. No matter what, the OP's mods had to weaken the K member. Does it cause a problem enough to notice, we'll see. but it it was flexing originally, and its certainly flexing more now.
If the OP is satisfied, fine, my first suggestion would be however was to radius his corner cuts as much as possible, to reduce a high stress riser source.
Re: Modified Early B Body K Member [Re: jcc] #1687761
10/20/14 12:30 PM
10/20/14 12:30 PM
Az
Crizila Offline
Crizila  Offline
Az
After
I would have issue's too, but if he ties the motor plate in to the rails that should stiffen things back up I would think.
Fastest 300
Re: Modified Early B Body K Member [Re: Crizila] #1687762
10/20/14 12:34 PM
10/20/14 12:34 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes it certainly would, but a K member is a 3d member, and a motor plate is effectively only 2d, and therefore is only a plane reinforcement, not ideal, but as you mentioned better, and completely dependent on the fastening method.
Re: Modified Early B Body K Member [Re: jcc] #1687763
10/20/14 01:44 PM
10/20/14 01:44 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You can lighten the K frame – but you should also have forward bars from the roll cage terminating forward or at the motor plate – that triangulates the front frame rails. It also helps to tie in the shock towers to the forward bars for added rigidity. If you do not have forward bars – its gonna flex with that much material removed. I like to see the motor plate mounted to the forward bars.
Re: Modified Early B Body K Member [Re: cudaman1969] #1687764
10/20/14 07:39 PM
10/20/14 07:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
After
I should have added that i'm doing an iron Hemi in my 64 Savoy also and want to make more room for the pan. I installed cm tubing to the front rails connected at the front k-frame bolt tying into the shock towers. Once i get the headers built i'll tie something from steering box bracket back to shock tower then maybe i can trim k-frame more(keeping it triangulated). If you get any direct feed back on flex let me know and we'll trade info. I want us all to have safe cars that go fast.
Re: Modified Early B Body K Member [Re: cudaman1969] #1687765
10/20/14 08:06 PM
10/20/14 08:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If the car in question has a properly installed roll cage, with snout bars and the engine plate mounts properly tied in to either the rails or the snout bars........the K-member does nothing more than hold the steering linkage and lower control arms
Monte
Re: Modified Early B Body K Member [Re: cudaman1969] #1687766
10/20/14 08:13 PM
10/20/14 08:13 PM
True this. I forgot to mention that a roll cage with forward bars should take up the slack in a door car with a K member modified.
I've left mine intact during my intensive weight loss program with the exception of the motor mounts being removed (Motor Plate) and adding a support gusset to the steering box mount. The Radiator support though very slim adds some rigidity to the front frame as well, but not much.
Keep an eye on that K.
Re: Modified Early B Body K Member [Re: fullmetaljacket] #1687767
10/20/14 08:33 PM
10/20/14 08:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Even with no cage, the motor and plate will do a better job of holding the frame rails together than the K-member anyway
Monte
