Fresh off the dyno!! My Max Wedge results #1687041
10/17/14 09:55 PM
10/17/14 09:55 PM
central ohio
mopar rookie Offline OP
central ohio
I just got home with my 500 ci maxwedge. RPM heads and A&A intake. Built by Badman Racing Engines in Wakeman Ohio. Here are the results. 527hp 600trq @5300. I tried to post a video but must be to big. But here is the sheet.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687042
10/17/14 10:33 PM
10/17/14 10:33 PM
central ohio
central ohio
I am pretty happy with the results. Out of the box heads and as cast intake. This is a hydraulic roller with Hughes roller rockers
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687043
10/17/14 10:37 PM
10/17/14 10:37 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Man that's a stump-puller! But why stop at 5300? There is more there.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687044
10/17/14 10:38 PM
10/17/14 10:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
You only spin it to 5,300?
Re: Fresh off the dyno!! My Max Wedge results [Re: ademon] #1687045
10/17/14 10:48 PM
10/17/14 10:48 PM
central ohio
central ohio
Yeah there is more there. He was trying to get the carbs leaned up and it was getting late in the day. It was more of a oversight than anything I believe. I was just a spectator more than anything lol
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687046
10/17/14 10:56 PM
10/17/14 10:56 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Are they out of the box RPM heads that are max wedge? If so where can you get them?
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687047
10/17/14 10:57 PM
10/17/14 10:57 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Very nice.
Do you mind sharing the cam specs.?
Re: Fresh off the dyno!! My Max Wedge results [Re: GY3] #1687048
10/17/14 11:29 PM
10/17/14 11:29 PM
central ohio
central ohio
The heads are just the RPM performer not max wedge. I didn't get the cam card but I will share the info when I do. On the first pulls the horsepower was falling off @5000 because the carbs were way to fat. Had to buy 2 kits to lean down both carbs. The carbs are leaned down as far as the kits would let us go and it's still a little fat.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687049
10/17/14 11:33 PM
10/17/14 11:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What carbs?
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687050
10/17/14 11:36 PM
10/17/14 11:36 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Does the intake have max wedge openings and mated to a standard port head?
Re: Fresh off the dyno!! My Max Wedge results [Re: GTS340] #1687051
10/18/14 12:07 AM
10/18/14 12:07 AM
central ohio
central ohio
Edelbrock carbs 500cfm. Intake and heads are standard 440 size ports
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687052
10/18/14 12:43 AM
10/18/14 12:43 AM
So it is a 440 stroker with unported Eddy RPM heads and a 440 port size A&A crossram, correct?
Re: Fresh off the dyno!! My Max Wedge results [Re: Cab_Burge] #1687053
10/18/14 12:47 AM
10/18/14 12:47 AM
central ohio
central ohio
Yes that's correct
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687054
10/18/14 01:32 AM
10/18/14 01:32 AM
Utah
topbrent Offline
topbrent  Offline
Utah
What cam?
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687055
10/18/14 01:36 AM
10/18/14 01:36 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
was there any O2 sensors hook up? also, just a note, it's October
Joe
Without Data, you’re just another guy with an opinion.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687056
10/18/14 11:03 AM
10/18/14 11:03 AM
Andrews,In. U.S.of A.
67_Satellite Offline
A/F ratio at 5.3:1? V.E. 50%? Were the choke plates wired shut?!?!
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687057
10/18/14 03:49 PM
10/18/14 03:49 PM
I thought so, I wish you had posted on here before buying your parts. The reason being the heads, intake and carb. sizes dictate what power the short block will be able to produce Stock 440 Mopars are head limited, the heads don't flow enough air to make much more power than you did I have made as much power as you did with ported big valve iron 906 heads, much more power than that with better heads I'm going to try to attach a dyno sheet from my most recent dyno tets, this is not a good result This test had lots of problems, mostly fuel and ignition related, I think I'm going to pull the motor down to inspect it due to the poor results, the last motor I built with similar parts made a lot more power on a different dyno BTW, leaning down the air fuel ratio can make a bunch of differences on the power, maybe as much as 50 to 125 HP No kidding The first 426 M.W. (real M.W. heads and intake )motor that I built and dyno tetsed made similar power on CA pump gas as yours did Adding cam timing and carb. and ignition tuning made more power
Re: Fresh off the dyno!! My Max Wedge results [Re: Cab_Burge] #1687058
10/18/14 03:58 PM
10/18/14 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hey Cab, send me your metering blocks and I`ll clean up the low speed/cruise and maximize the wfo.............
Re: Fresh off the dyno!! My Max Wedge results [Re: Cab_Burge] #1687059
10/18/14 05:38 PM
10/18/14 05:38 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
His looks like my 380 but down in HP. I'll give em the torque number though. Mines only 490ftlbs.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687060
10/18/14 06:56 PM
10/18/14 06:56 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
was there only one air turbine on the engine? because that would account for some of your strange numbers.
Joe
