Hemi sheet metal cross-ram intake - what do I have? #1686840
10/17/14 01:39 PM
10/17/14 01:39 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I may be taking this in on a trade and need some help on what it is and what it's worth and how hard it will be to sell.
Thanks in advance for anyone that takes a few minutes to help me out.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686841
10/17/14 01:40 PM
10/17/14 01:40 PM
Tulsa, Ok
Tulsa, Ok
side
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686842
10/17/14 01:40 PM
10/17/14 01:40 PM
Tulsa, Ok
Tulsa, Ok
top
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686843
10/17/14 02:27 PM
10/17/14 02:27 PM
indiana
ss/ah3480 Offline
ss/ah3480  Offline
indiana
old hemi sheet metal ss intake...would think it would be hard to sell...and even to the right guy i cant imagine it worth more than 300-400
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: ss/ah3480] #1686844
10/17/14 02:34 PM
10/17/14 02:34 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
the linkage and throttle bracket, springs etc. go for $295 new. if that helps.
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: old_racer] #1686845
10/17/14 02:40 PM
10/17/14 02:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
do you have a hemi you can set it on to check if it will even fit anything because they do some funky stuff in SS
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686846
10/17/14 02:54 PM
10/17/14 02:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unless you want it as a conversation piece or are getting it dirt cheap I do not see a lot of value there. Cool part but not a big market for it.
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: Al_Alguire] #1686847
10/17/14 03:04 PM
10/17/14 03:04 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
That was built for a SS car that had to keep the carbs in stock location. At some point (maybe late 90's?) they changed the rules to allow the carbs to be relocated, but they still must be offset by a small amount.
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: Al_Alguire] #1686848
10/17/14 03:29 PM
10/17/14 03:29 PM
an8sec70cuda Offline
The port shape is usually unique to the heads used in SS/AH (rounded or sort of figure 8 shaped) and it's probably made to fit a block that has been decked A LOT...like 1/4" or more.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686849
10/17/14 03:33 PM
10/17/14 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'd think some street-squeaker would grab it up just for the novelty.
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686850
10/17/14 03:59 PM
10/17/14 03:59 PM
AndyF Offline
AndyF  Offline
As pointed out the port shape and deck height are probably one of a kind. That intake may not bolt onto anything other than the combo it was built for.
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: AndyF] #1686851
10/17/14 04:11 PM
10/17/14 04:11 PM
Dyno1 Offline
Dyno1  Offline
You are always best to buy intake/heads together as a package, otherwise you will have fitment issues. Plus most hemi combo's are decked .100 to .500", which is OK as long as you have the correct pistons for it. Dyno
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: Dyno1] #1686852
10/17/14 04:44 PM
10/17/14 04:44 PM
Tulsa, Ok
Tulsa, Ok
Thanks for the help guys, not exactly what I was wanting to hear but it's what I needed.
I've got $750 in it so hopefully I can get that out of it...
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: WadeMetzinger] #1686853
10/17/14 09:23 PM
10/17/14 09:23 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
With these things you'd have to know the engine combo it came off of to make it work or have it worth anything to anybody. As was mentioned alot of funky stuff was/is allowed in SS/AH so whereever it came from, the guy had a specific set-up it worked with. Chances of finding someone that has the exact same set-up is slim, anf putting more money into it hardly seems worthwhile, IMO as that can get pricey between flow time & welding time. For what it's worth, to me it looks like an early Ray Barton design.........
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: an8sec70cuda] #1686854
10/17/14 09:26 PM
10/17/14 09:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
HAPPY B-DAY...............
Re: Hemi sheet metal cross-ram intake - what do I have? [Re: Thumperdart] #1686855
10/17/14 10:21 PM
10/17/14 10:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Got one just like it, mine made by Hogan and fits the standard deck height. Carbs set different than the original crossram so linkage attaches to right side of one carb and left side of other. They had to work better than the old crossram or they wouldn't have made it. Back in the day Bob Reed told me the biggest factor holding the SS back was the restricted intake. If its been cut for low deck, spacers can be easly made no big deal. In fact i'll have to cut mine or raise the heads.
Any carb combo, just make new top plate. Mine will be street car so real good wow factor. What says Hemi more than a "tunnel ram" crossram
